Thread: 2003 Grand Am Crank no start 2.2l ecotec
Results 1 to 10 of 10
  1. #1 2003 Grand Am Crank no start 2.2l ecotec
    Donating User
    Aug 2016
    MI
    Chats
    I have a 2003 grand am with the 2.2l ecotec engine. one day a couple months ago i started the car and it sounded like it wasnt going to start for a second but it fired up. The idle was really low at first and slowly built up to normal idle. i drove the car to work and parked it. But when i went to leave it was just cranking over and over not even trying to fire. It has spark, fuel pressure, and the timing chain is not busted. The lifters also look fine, nothing broken. the plugs look fine but dont seem very wet. Also all the Pistons are moving and it has compression ( I dont have a tester to check actual numbers). What am I missing here?
  2. #2 Re: 2003 Grand Am Crank no start 2.2l ecotec
    SWPA
    Chats
    33
    It sounds like the injectors aren't firing. Spray some fuel or starter fluid into the throttle body and see if it fires up and shuts off.
  3. #3 Re: 2003 Grand Am Crank no start 2.2l ecotec
    Donating User
    Aug 2016
    MI
    Chats
    Bad News. I took the valve cover off to take another good look and this time I noticed the timing chain sagging. It gets tight and then loose again. it also jumped timing a little bit. Im pretty sure the tensioner is shot. Ive got my fingers crossed that the valves will be ok.
    https://youtu.be/c-7qq1fYCwQ
  4. #4 Re: 2003 Grand Am Crank no start 2.2l ecotec
    Donating User
    Aug 2016
    MI
    Chats
    More bad news. The top bolt for the main chain guide snapped somehow, which caused the chain to break the tip off the guide. I wasn't sure how to get the broken piece out, so my solution is to weld the broken bolt to the back of the plug.
  5. #5 Re: 2003 Grand Am Crank no start 2.2l ecotec
    Donating User
    Aug 2016
    MI
    Chats
    I have pictures, but it's impossible to upload them.
  6. #6 Re: 2003 Grand Am Crank no start 2.2l ecotec
    SWPA
    Chats
    33
    Upload them to photobucket or another pic hosting site and paste the link here using the img codes
  7. #7 Re: 2003 Grand Am Crank no start 2.2l ecotec
    Donating User
    Aug 2016
    MI
    Chats
  8. #8 Re: 2003 Grand Am Crank no start 2.2l ecotec
    Donating User
    Aug 2016
    MI
    Chats
    I know welding the broken bolt to the plug isn't ideal. But I dont know how to fix it without pulling the whole engine out.
  9. #9 Re: 2003 Grand Am Crank no start 2.2l ecotec
    Donating User
    Aug 2016
    MI
    Chats
    UPDATE: Welding the broken bolt isn't going to work. But I found this bolt online that is exactly what I was trying to make. Apparently this is a very common in the 2.0 2.2 and 2.4 engines. If you know anyone who has this problem show them this listing. This bolt saved me alot of time.
    http://m.ebay.com/itm/152558859307
  10. #10 Re: 2003 Grand Am Crank no start 2.2l ecotec
    Donating User
    Aug 2016
    MI
    Chats
    The car is back together and runs great. I highly suggest this new front chain guide bolt fix to anyone who has the 2.2 or 2.4 ecotec engines. It saved me the trouble of having to pull the head and drill out the broken bolt. And it eliminates a major weak point in the timing.
  1. 2004 Grand Prix No Start No Crank
    By Charles20212 in forum General Tech Discussion
    Last Post: 06-14-2014, 05:41 PM
  2. 2004 Grand Prix, No Start, No Crank! Help!
    By jbybee4 in forum General Tech Discussion
    Last Post: 04-01-2014, 05:49 PM
  3. Replies: 3
    Last Post: 11-29-2012, 05:06 PM
  4. Crank, but no start
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 11:28 PM
  5. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
