Thread: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
Page 4 of 4 FirstFirst ... 234
Results 61 to 78 of 78
  1. #61 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    The black plastic ones will still work just fine.
    Any of the new coolants out there won't eat away the gaskets anymore. I still prefer the updated design but the plastic can still work if you need to use them.
    Thanks
  2. #62 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    Quote Originally Posted by ItHurtz View Post
    yesbuttherereallyisnopoint...yaynospacebaragain
    You'reright,whatisthepoint........ Any major gain in a N* or LS TB? If it will help Knock retard I'll go through the hassle of switching, if not then forget about it!
  3. #63 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Neither would reduce knock.
    They are just larger to allow more air if the engine is able to use the extra airflow. Throttle feel can vary between them as well because of size/design.
  4. #64 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    Subbie is back on the build! After calculating all the Subaru specific parts that I've accumulated over the last year has convinced me to over ride the wife. Plus, it just seems like such a good idea.....
  5. #65 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Antioch, IL
    When its comes to toys wives dont have a say. Mine said she was leaving if I bought turbo, she lied.
    2009 Challenger SRT8
    Expert at being gay.
  6. #66 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    Nice....I try to comply with most requests, just to keep the peace, but she couldn't argue with my logic on this one!
  7. #67 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    hangover park IL
    Well she figured out to use the budget requisition system of making you have another mouth to feed
    ~James~ Psychotic Gearhead
  8. #68 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    ported the throttle body today...
    Found a thin spot..... LS1 TB here I come. I think I'll keep the stock MAF but put it in the intake tube ahead of the TB.
    Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise! Attached Images
  9. #69 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    Does anyone have access to the harness/ecm pinouts for the 03' gtp L67?
  10. #70 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    OK - got an issue, maybe. Putting in a new Melling oil pump and after torqueing it 96 in lbs freezes up solid. The old pump moves some what freely. The old pump cover does have some wear. I measured all the parts and they all measure the same. Does anyone have experience with this Melling pump (K195)? Maybe its the new cover with its phosphate looking coating?
  11. #71 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Antioch, IL
    You do step #1 correctly? Inside gear chamfer has to face oil pump cover.
    20161206_225100 by Corey S, on Flickr
    20161206_225224 by Corey S, on Flickr
  12. #72 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    Sure did... I tried the new gerator set with the old cover and it spins with a slight resistance. The old gerator set works with the new cover the same. The new gerator set and new cover locks up solid. I'm going to take it to the machine shop tomorrow and have everything mic'd to see where the issue is....thanks.
  13. #73 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    hangover park IL
    you may have gotten a plus-sized oil pump for worn-out timing covers
  14. #74 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    The Melling website only shows one option - off to the machine shop I go!
  15. #75 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    Fixed the oil pump - It was the inside gerator, took off .0005 and it work like a champ! Now I can say that the oil pump is custom and blue printed...
  16. #76 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    So after that fiasco I'm wondering about oil pressure. From what I understand the 3800 has an issue with the connecting rods not getting enough oil. Is this due to not enough volume, pressure, or both?
  17. #77 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Antioch, IL
    Connecting rods can egg over time, has nothing to do with oil. There can be oiling improvements made in the engine but meh.
    You can increase oil pressure by buying zzp oil volume kit, or you can shim the factory cap some like 1/4" washer inside.
  18. #78 Re: Swapping a 03' GTP SC 3.8 into my 07' Subaru WRX need advise!
    Aug 2016
    Utah
    1/4" thick washer inside the cap? That's the way we used to do the old school SBC. Same principle I guess.
  1. Subaru BRZ vs........ Land Yacht
    By BillBoost37 in forum Track Sessions and Kills
    Last Post: 10-10-2014, 11:30 AM
  2. The following was admitted by a subaru owner...
    By Chad Gervais in forum Off Topic Discussion
    Last Post: 08-24-2012, 04:25 PM
  3. 2003 Subaru
    By Ballin00gtp in forum Members Rides
    Last Post: 11-10-2011, 10:02 AM
  4. Subaru WRX 04
    By GAFF in forum Track Sessions and Kills
    Last Post: 04-08-2011, 01:40 PM
  5. GTP vs Subaru
    By Nickell in forum Track Sessions and Kills
    Last Post: 11-09-2009, 02:37 AM
