Thread: Project LQ4 - V8 S10 - Sold.
Page 51 of 66 FirstFirst ... 41495051525361 ... LastLast
Results 1,001 to 1,020 of 1306
  1. #1001 Re: Project LQ4 - V8 S10 - Pictures work again!
    Yeah, white is easy to make it look clean.
    When I bought my 06 sierra it had 254,000 miles on it. I buffed the whole car once and past that it could be mistaken for a truck with 1/3rd the mileage and wear even when I didn't wash it.
  2. #1002 Re: Project LQ4 - V8 S10 - Pictures work again!
    Jul 2010
    Coquitlam,BC,Canada
    She looks good; clean and stealthee.
    I've always liked dark colours, but after having a silver car I have a new appreciation for how clean they can look when they are filthy dirty. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #1003 Re: Project LQ4 - V8 S10 - Pictures work again!
    Mar 2014
    Tucson
    Agreed. Not to mention the thermal advantage. White or light will always outsell black or dark colors in the southwest.
    Quote Originally Posted by Bronco Boy View Post
    Thanks! We get a lot of fine dust blowing around here. Previous car was bronzemist, and that hid the dirt VERY well too.
  4. #1004 Re: Project LQ4 - V8 S10 - Pictures work again!
    Mar 2014
    Tucson
    Finished looming the main harness
    Chasing down a P01637. Could be a bad connection somewhere, or my new 145 amp alternator is toast already. Skimming through Google, it sounds like these systems are pretty fussy about what replacement alternator you use. I'll run through the diagnostics and see if I can figure it out. I still have the old 105 amp unit to fall back on, and the new one should be under warranty... She bogs/breaks up bad and goes stupid lean under hard acceleration. I'm chalking that up to the P01637 issue. Could also be a plugged fuel filter I guess. I have a new one on the shelf that's going on soon.
  5. #1005 Re: Project LQ4 - V8 S10 - Photobucket hosed me.
    Jan 2014
    AR
    So have the kiddos come up with a name for it yet?
  6. #1006 Re: Project LQ4 - V8 S10 - Pictures work again!
    Mar 2014
    Tucson
    Ha! No, they just call it "The white one..." They all seem to enjoy riding in it though.
    One of my boys has already claimed it as his when I die. Let's just say. I don't let him hold the ladder for me.
  7. #1007 Re: Project LQ4 - V8 S10 - Pictures work again!
    Quote Originally Posted by BrandonHall10 View Post
    thats hilarious lmao.
  8. #1008 Re: Project LQ4 - V8 S10 - Pictures work again!
    Mar 2014
    Tucson
    Alternator tested fine. I might have been chasing a red herring with the P1637 code. Backburner that for now because... I think I found the bogging issue
    Fuel filter was BAD. Won't know for sure until I get it warm and really hammer on it. Either way, it needed to be changed. That's the only disadvantage of living where nothing rusts; you can't tell how old a fuel filter is by looking at it. Outside was pristine. No rust at all. I guess all the rust was on the inside. LOL
  9. #1009 Re: Project LQ4 - V8 S10 - Pictures work again!
    Antioch, IL
    I hate you and alllll the clean things
    2009 Challenger SRT8
    Expert at being gay.
  10. #1010 Re: Project LQ4 - V8 S10 - Pictures work again!
    Mar 2014
    Tucson
    Quote Originally Posted by ItHurtz View Post
    Take the good with the bad. It's September and we still hit 105° today. I can't wait for Fall/Winter.
    Well, the truck is better. The filter helped, but it still leans out under hard acceleration. Especially once it goes into PE. I can watch the wideband swing from 14.7 to 12.5 then creep back to 16+ before I get a chance to let out. So, this afternoon, I pumped the tank empty. I'll pull the module tomorrow. I have to believe the pickup screen is almost plugged solid. Might have something to do with the 3 gallons of E85 I pumped in the other day...
  11. #1011 Re: Project LQ4 - V8 S10 - Fueling issues...
    Mar 2014
    Tucson
    So I pulled the module. The sock was pretty bad.
    Not as bad as I would have expected, but I think I know why... The problem really only presented after the truck ran for a little bit. I assumed it was an issue with the truck being warm. Now I think it's because of that sock filling up over time. Nothing to do with heat. Basically, run the pump, sock fills up. Shut the truck off, crud falls away from the sock. Repeat every drive cycle. All the junk in the tank kind of confirms this theory. Here's what's left over from the last little bit of fuel siphoned out of the tank.
    Here's the inside of the tank after a thorough scrub with a wire brush, some scotch brite, a good rinse and a towel dry.
    Then I dumped in some OSPHO and sloshed that around. I ordered up a pint of the POR-15 tank sealer. Should be plenty of time for the OSPHO to dry before it arrives.
    Also did my first and hopefully only ricer mod. The tank shield was cracked, so I stitched it back together.
  12. #1012 Re: Project LQ4 - V8 S10 - Fueling issues...
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Very wise to drill that hole at the end of the crack to keep it from growing. What, no black zip ties ? lol
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  13. #1013 Re: Project LQ4 - V8 S10 - Fueling issues...
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    If that's what you call a ricer mod, I'm curious what you would call having a giant wing and fart can...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  14. #1014 Re: Project LQ4 - V8 S10 - Fueling issues...
    Mar 2014
    Tucson
    Quote Originally Posted by cheatah faheatah View Post
    I save those for where looks really matter... Under the hood.
    Quote Originally Posted by WarStryker13 View Post
    Obnoxious.
  15. #1015 Re: Project LQ4 - V8 S10 - Fueling issues...
    Mar 2014
    Tucson
    Tank sealer came today. Probably could have gotten away with the 8oz. can, but $5 more got me a full pint. This stuff reminds me of the old silver or chrome Testors model paint. In color and smell. Not sure why I expected black, but this stuff was definitely not black.
    Now for the 96 hour cure time. Between baking it in the sun and blowing it with the fan, I'm betting it will plenty dry in 4 days. Fingers crossed, I should be able to put it back together for the weekend.
  16. #1016 Re: Project LQ4 - V8 S10 - Fueling issues...
    Antioch, IL
    Any reason you chose Por over KBS's system?
    https://www.kbs-coatings.com/3-Step-...ng-System.html
    96hr cure times, holy sht.
  17. #1017 Re: Project LQ4 - V8 S10 - Fueling issues...
    Mar 2014
    Tucson
    No reason in particular. I Googled "fuel tank sealer" and the POR-15 stuff was the first (and maybe only?) result. The reviews were almost all positive so I stopped looking.
    I think that's worse case scenerio. Imagine you got a 50 gallon diesel tank with a 2" fill hole sitting in a cool garage. It's going to take a long time for those VOC's to off-gass. I have an 18.5 gallon tank with a 4" opening at the top, a 2" filler tube and a 3/4" vent hole. Plenty of air flow. Plus I have it sitting in the 100° sun during the day, and a fan blowing at night. Less than 24 hours after application, I barely smell any fumes and it's hard to the touch.
  18. #1018 Re: Project LQ4 - V8 S10 - Fueling issues...
    thats some mean looking stuff.
  19. #1019 Re: Project LQ4 - V8 S10 - Fueling issues...
    Mar 2014
    Tucson
    Time will tell, but I'm really impressed with it right now.
    Tank is back in. It can spend the next 48 hours drying in the truck.
    While it was out, I hit the bottom with some leftover spray on bedliner. I like the way that turned out.
  20. #1020 Re: Project LQ4 - V8 S10 - Fueling issues solved.
    Mar 2014
    Tucson
    Well I'm going to consider my fueling issue solved. Went WOT a couple times and the AFR held steady at the commanded 12.5(ish). I guess when you don't have a bunch of rust sloshing around in your tank, the fuel can actually get to the injectors...
    Now that the tank is sealed and I have all the bits for the injector swap, might be time to throw the GTP injectors in and try a little E85!
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. Replies: 17
    Last Post: 12-28-2012, 04:17 PM
  3. Heres a 1997 GTP my friend is interested in. Any good or bad things bout them?
    By burgundybullet in forum General Grand Prix Discussion
    Last Post: 02-21-2012, 02:29 AM
  4. Can't WAIT !!!!
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 07-17-2011, 11:16 AM
