Thread: Big Block guys... step in...
Results 1 to 20 of 24
  1. #1 Big Block guys... step in...
    Chats
    7076
    soooo since KCIR closed and I dont wanna bring the car all the way to Heartland Park... Ive decided to turn my race car into more of a "Sunday driver" if ya know what I mean...
    question is... Its a completely built up carbed 540 motor that buts down close to 800hp to the wheels...
    I have a Powerglide in it right now but obviously dont want that to just cruise around in... what kind of trans options do I even have out there for this thing? T56 with a bause clutch maybe?
    I prefer a manual but its not a must...
    thanks for any inputs...
    Jarred
  2. #2 Re: Big Block guys... step in...
    Chats
    243824
    id go with a th 400 and a 2500 stall 3.70 or 3.93 gears so it will still run the highways.
    4 speed were fun back in my youth, and im a truck driver so manual for cruising is out in my book. would be real frigging sick tho with a good 4 speed and 800 hp.
    my bro had a 462, (454 .30 over) estimated at around 650 hp ( 7 grand in engine parts alone in the late 80's) th 400, 4.11 gears, full posi unit installed as well in a 12 bolt rear. the trans was a B and M built with a full manual valve body.and a 3200 stall in a 72 chevelle. that came as a 4 speed and stock 10 bolt rear and a 302 i think.all were scrapped, and replaced.
    this thing used to break the tires lose at 40 with out trying, and ran a 12.6 in the 1/4 at 106 mph. full car, no weight reductions made.
    turned into this monster, in this shot it has the slicks on it, he ran vette rally wheels.
    i really wish we had a vid of this car, it sounded a lot like
    02 WS6 TA's car. when it was cold out, it blew exhaust smoke rings out the tail pipes, you could really see each cylinder fire, and they shot out from the rear axle where the pipes dumped.
  3. #3 Re: Big Block guys... step in...
    Chats
    243824
    sorry i meant 3500 stall converter, not a 2500 lol
  4. #4 Re: Big Block guys... step in...
    GT Level Member sic6's Avatar
    san marcos, tx
    Chats
    You could also run an 4L80E transmission. i like those better that the turbo 400's due to the fact it has an overdrive and the ratios are close.
    97 GTP
  5. #5 Re: Big Block guys... step in...
    Chats
    40479
    why cant you drive a glide on the street? ive seen literally hundreds of dudes do it.
  6. #6 Re: Big Block guys... step in...
    Chats
    243824
    not sure what kind of car your working on but you may need some kind of commuter interface to run that trans, its electronic,(they sell it) vs the th400 being vac operated for the most part.
    OD would be nice to have.
    if you did have a OD i bet you could get away with 4.11 gears and not be screaming on the highway.
    @50 mph my brothers car was doing over 3,000 rpm's, screaming! this car didnt make real power till 3200 rpm's and red lined at 5800 to 6000 iirc. big blocks dont really like hi rpm's, had lots of friends with 9,000 rpm small blocks tho.
    he took back roads all the way to the track after his first highway drive. and this was his daily driver.
    as fast as his car was, a 2 hour drive down the shore would take him 3 hours lol he drive rt 9 all the way there, (in the slow lane) vs the parkway.
  7. #7 Re: Big Block guys... step in...
    Chats
    243824
    power glides is a s 2 speed trans, not good for out side the track. sure it be fun but mpg will suffer greatly. why stick with 2 when you can 3 or 4 gears?
  8. #8 Re: Big Block guys... step in...
    Chats
    40479
    i realize its a 2 speed. but if youre gonna just cruise it for fun every so often and not going on any real trips, **** take it out on the glide. i would.
  9. #9 Re: Big Block guys... step in...
    mi
    Chats
    2736
    lol at mpg woes with 540ci. Glide will be fine. 2nd gear is 1:1
    My bet is op doesnt own said car tho.
    btw big blocks love rpm's too
  10. #10 Re: Big Block guys... step in...
    Chats
    40479
    he owns it. seen it when we were down there for the KCMO meet.
  11. #11 Re: Big Block guys... step in...
    Chats
    243824
    what is it? the car that is?
  12. #12 Re: Big Block guys... step in...
  13. #13 Re: Big Block guys... step in...
    Chats
    243824
    and when you are getting 8 gallons to the mile, (yeah i typed that right,) every mpg helps. a worked big block drinks gas, theres no granny driving saving you form poor mpg. why more gears are more better. running around town at 2200 rpms is far better than 3500 gas wise. and a high stall will kill your mpg, but at least it will make power off the line with it.
  14. #14 Re: Big Block guys... step in...
    mi
    Chats
    2736
    you can buy lots of gas for the price of a built th400 even more so w/a viper spec t56. The torque of a big block would make the need for a 3rd gear moot.
    Glides are nearly indestructible. Manuals are hard on everything.
  15. #15 Re: Big Block guys... step in...
    Jan 2012
    Louisiana
    Chats
    733
    6060 with a clutch and decent build. Check our gforce, rpm and a few others.
    Chats
    64942
    Tremec regulates the cost quite well....
  17. #17 Re: Big Block guys... step in...
  18. #18 Re: Big Block guys... step in...
    Chats
    7076
    1970 nova SS
    Do I own the car?
    yes
    Did I build the whole thing?
    no
    Long story short I inherited it...
    I guess I could keep the glide as I dont plan on ever taking it on the highway, the tranny is more of an idea than a must right now as Im looking for a bause radiator and wheel/tire setup...
    just kinda thought itd be fun to have a few more gears because im setup to go about 6800-7000 rpm... little more fun to drive (if thats possible)
    thanks for the input fellas, gives me something to kinda start researching... keep em coming though as Ive never really done anything like this before...
  19. #19 Re: Big Block guys... step in...
    Chats
    243824
    nice ride, looks like a beast. is it tubed? gutted and caged?
    i'd look for a big ol fat rad to put in it, and 2 electric fans. electric fans can run full speed all the time, so you should never have a problem on the road overheating. even on a hot day in traffic.
    back in the day a friend of mine bought this 67 1/2 camaro, (for 5 large delivered) caged, tubed, no engine or trans, but it came with 5.33 gears in a spool rear end, with 33 street slicks, fuel cell in the trunk, car was set up for 1/8 mile runs. we put the engine and trans from my brothers chevelle in and drove it on the street. car was a neck breaker. spool rear end and skinny tires up front dont mix well for taking turns on the street lol
  20. #20 Re: Big Block guys... step in...
    Chats
    7076
    all of the above...
    Ive got a pretty good idea on the radiator setup im gonna do... this one is obviously not gonna be big enough for street driving but then again it was never designed for that...
  1. cat-less guys step in
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-08-2009, 01:46 PM
  2. Guys who run slicks, step in......
    By Iron Indian in forum General Tech Discussion
    Last Post: 07-30-2009, 12:10 AM
  3. Nitrous Guys Step In!!
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-04-2008, 05:38 PM
  4. L26 Guys....Step on in.
    By Reptile in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2008, 07:50 AM
