Thread: Bandook's 01 Imp, top swap-ified
Page 23 of 32 FirstFirst ... 132122232425 ... LastLast
Results 441 to 460 of 632
  1. #441 Re: Bandook's 01 Imp, top swap-ified
    you used plastic lim gaskets...replace with metal ones. it looks blown out.
    you might have put that there but it also could have happened from sitting, cant be a head gasket, no way for it to push it on top of the valve, unless the head is cracked.
  2. #442 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Yeah when I saw the plastic gaskets I suddenly remembered installing them, thinking I'd have got rid of the car by now. I originally had metal ones that I installed when I first got the car, but a month later I stuck the blower on and used plastic.
    I'm pulling the heads now. That loose valve stem I couldn't let slide. So I'll check them over and get a quote to install bronze guides if needed. Perhaps a couple upgrades. But who knows, I might find a toasted piston.
    Top Swapped 01 Imp
  3. #443 Re: Bandook's 01 Imp, top swap-ified
    the spark plug would have been smashed if the piston chipped.
  4. #444 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    How was the seat of the pants experience when you installed rockers?
    Top Swapped 01 Imp
  5. #445 Re: Bandook's 01 Imp, top swap-ified
    they were my first mod i installed. the car felt better cause they killed 5 of my 8º's of KR, id drop a cam in it vs rockers if i was do it over again.
  6. #446 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    I might go that route. I'm thinking of pulling the engine now. I have to sooner than later do the oil pan gasket, and possibly the rear cover gasket. If I decide to, it's gonna be a long project. Daughter goes in Tuesday for braces, so my mod funds are gonna dry up for awhile. �� But if I do cam I need to consider a tranny rebuild. Crap, what have I gotten myself into. I'm almost hoping I find a melted piston...
    Top Swapped 01 Imp
  7. #447 Re: Bandook's 01 Imp, top swap-ified
    St. Louis
    You found the modding rabbit hole, lol. I started down that road with my GPGT and then reality set in and I made a plan to mod it and am sticking to it. I know what needs to be bought/upgraded and the $$ it will take and that's where it stops. Once it's together and running good I'll let it ride and enjoy it for what it is.
    All that matters is that I enjoy it when it's done
  8. #448 Re: Bandook's 01 Imp, top swap-ified
    Kemmerer, Wyoming
    I run an XP cam and love it.
  9. #449 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Valve wiggle wiggle - YouTube
    Short vid showing how much movement is in the valves. Head gasket was fine. I know that the chances of it failing were slim, but I had to know. Obviously I screwed up the valve seal install. If I use this head I'll replace all of them. Wonder what the tolerance is for valve wiggle.
    Top Swapped 01 Imp
  10. #450 Re: Bandook's 01 Imp, top swap-ified
    Kemmerer, Wyoming
    I think you should take the heads to the machine shop and get a multi angle valve job done. and while they are there, get them machined so you can run an xpz cam.
  11. #451 Re: Bandook's 01 Imp, top swap-ified
    seems like a lot of wiggle to me.. pull the valve out, check the stem for wear.
  12. #452 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Ya, I agree. Gonna pull the other head and take them to the machine shop. I could pick up another set at the yard, but I've got so much time and money in these I gotta find out if they are worth fixing. Are there gains to be had with bigger valves, without rocker/cam?
    Top Swapped 01 Imp
  13. #453 Re: Bandook's 01 Imp, top swap-ified
    im not sure how much bigger you could go. they almost touch as it is.
  14. #454 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    With all the slop in them, I'm surprised they haven't touched.
    Top Swapped 01 Imp
  15. #455 Re: Bandook's 01 Imp, top swap-ified
    Kemmerer, Wyoming
    when I went smaller than 2.8 on the gen 3, I didn't notice much more power. doing rockers and a cam will necessitate measuring pushrod's.
  16. #456 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Alright, cool. So if the heads check out and don't brake the bank, I'm thinking VS cam (because it's much cheaper since I don't have to do chain, big springs, oil pump cover etc) and I'll dial it in on the Gen 3. Then later I can do Gen V when I find a nice one.
    Top Swapped 01 Imp
  17. #457 Re: Bandook's 01 Imp, top swap-ified
    GT Level Member mguzzo's Avatar
    Buffalo NY
    The VS cam is nice. not too lopey, but really good midrange torque. On a goodsetup (VS, 3" pulley, intercooled, headers, and tune) you'll put down 300 whp and run low 13's high 12's all day long.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  18. #458 Re: Bandook's 01 Imp, top swap-ified
    Kemmerer, Wyoming
    you can get a good used gen 5 for like 125 bucks off LKQOnline I would also do a northstar throttle body and LQ4 maf at the same time.
  19. #459 Re: Bandook's 01 Imp, top swap-ified
    Oct 2014
    portland oregon
    Ching ching cha ching.. Will the madness ever end?
    Sent from my SM-N920V using Tapatalk
  20. #460 Re: Bandook's 01 Imp, top swap-ified
    gen 5 swap ran me about 400 bucks in all, 117 shipped for the blower, 30 for a used N*, 50 for a maf, n* to gen 5 adapter plate and pig tail 130, 15-20 iirc for the blower bolts for the ic and gen 5, then like 90 for the 4 inch intake tube couplers and new filter.
    then i sold my gen 3 belt wrap for 125 and bought one for the gen 5 for 150. so 25 more lol it adds up fast.
  1. Couple questions regarding build in progress
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2013, 11:03 AM
  2. Top swap Progress
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-15-2012, 05:55 PM
  3. Top Swap progress
    Last Post: 09-14-2012, 07:04 PM
  4. Pics of my swap progress
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2010, 02:44 PM
  5. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
