Thread: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
Results 1 to 16 of 16
  1. #1 TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Mercer, Pa
    Chats
    10
    New Harrop TVS2300 (htv2300) Supercharger
    Phenolic and Aluminum Intercooler/Adapter
    TB Adapter to North Star or Gen 5 TB
    Supercharger is COOL TO TOUCH when engine is running!
    Fits under most hoods, the TB is actually lower than my Gen 5 supercharger w/ intercooler
    Contact me for information!
    https://www.facebook.com/ed.labarge/...3362332708038/
  2. Likes 1fastam, SaukRapids, Pursell1911 liked this post
  3. Advertisement
  4. #2 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Chats
    Can you tell me more information? What are the benefits verse a turbo for the price? What about the difference between the stock supercharger? Have you dyno? Obviously it runs cooler so does that translate into running more boost? How much more or where do you reach limits of efficiency or engine safety?
    Brett
  5. #3 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Mercer, Pa
    Chats
    10
    Sorry, no dyno results yet, but yes I'm running more boost without any other changes. I swapped from m90 w/2.8" pulley to TVS w/3.8" pulley, boost exceeds the MAP sensor 14.7psi at 5,000 RPM.
    Engine safety? Not sure I can answer that, its a big supercharger able to push PSI into the 20's with supporting modifications and tuning just like big turbo.
    Modifications that effect how far you can go are Cam, Headers, Ported Heads, Exhaust, etc.....
  6. #4 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    SE Level Member KShef's Avatar
    West Palm Beach
    Chats
    6
    This is neat and good to see people in the community continue to innovate.
    Any sound clips or videos under throttle?
    Park Ave, turbo
    13.1 112.9
  7. #5 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Jul 2012
    Clayton,NC
    Chats
    So what is the wait time on one of these kits?
    Would it be possible to get an adapter for say a 90mm ls1 TB?
  8. #6 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Mercer, Pa
    Chats
    10
    3 to 4 weeks. I would do an adapter to 90mm TB.
  9. Likes KShef liked this post
  10. #7 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Mercer, Pa
    Chats
    10
    Dyno results.
    TVS2300
    (2300 is equal to a M140 supercharger or 1.55 times bigger M90)
    Stock cam
    1.94 rockers
    E85
    North Star
    Headers
    360 hp
    443 torque
    17-18 psi boost
    3.5 pulley
  11. Likes Iceman6669, KShef liked this post
  12. #8 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Chats
    36
    like the amount of torque down low. this is at the crank correct? I noticed the first graph shows engine power and if so, that's ~288/354fwhp
    how much timing? also no vids?! would like to hear what it sounds like under WOT
  13. #9 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Jul 2012
    Clayton,NC
    Chats
    No thats whp. Its showing power by wheel speed. That pull must have been in 2nd gear.
    That combo needs a cam and ported heads with a bigger throttlebody.
    Would probably make closer to 450whp with better in and out flow. On less boost too.
  14. #10 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Chats
    36
    IIRC a 2nd gear pull usually shows higher horsepower and not a 1:1 gear which is 3rd gear.
  15. #11 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    May 2008
    Schuyler, NE
    Chats
    262
    2nd gear dynos are usually a bit lower than 3rd, but still very close.
    2001 GTP Drag Car - XPZ, Tischler heads, NB intercooler, e85, Gen V, 2.3 w/ 5%OD
    2005 F350 6.0 - studded, deleted, bulletproofed, tuned
    1966 Olds Cutlass 442 Convertible
  16. #12 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Nov 2011
    NY
    Chats
    1646
    Just being able to touch the SC and see the heat difference is like running an intetcooler...
    Sub'd...
    Maybe a future upgrade
  17. #13 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Jul 2014
    Greenville SC
    Chats
    Were you seeing kr on a smaller pulley? Running out of fuel? Diminishing gains? Just curious why you went with a 3.5". What size is the opening for the TV? 90mm? Could it be ported to 102mm?
  18. #14 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    GT Level Member mikejohnlewis's Avatar
    Jul 2014
    Manchester, Iowa
    Chats
    127
    got facebook messenger or a good way to communicate? im pretty interested in a setup this should look pretty good ontop of my new zzp heads
    1997 Grand Prix GT 3.8(SOLD)
    1996 Camaro RS Coupe 3.8(SOLD)
    1994 Dodge Ram 5.2(Ugly winter truck)
    2002 40th Anniversary Coupe GT (Current)
  19. #15 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    Chats
    13246
  20. #16 Re: TVS2300 Supercharger Kit,Phenolic Aluminum adapter/intercooler TB adapter, $4500
    Mercer, Pa
    Chats
    10
    I just made a second one, so its not a one of a kind anymore.
  21. Advertisement
  1. Phenolic Aluminum Hybrid Intercooler Gen 3 & 5
    By sseilmnop in forum LaBarge Supercharged
    Last Post: 11-27-2018, 09:22 AM
  2. Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    By sseilmnop in forum How To Write-Ups/Tech Tips
    Last Post: 06-15-2017, 11:15 AM
  3. Replies: 2
    Last Post: 01-26-2017, 05:56 AM
