Thread: Broken Rear Manifold Stud...
Results 1 to 18 of 18
  1. #1 Broken Rear Manifold Stud...
    Banned
    Oct 2013
    Moorhead, MN
    Fastener stud between the crossover and the rear manifold snapped...
    Anyone have experience with this situation?
    My next attempt will be with a razor blade across my wrists.
  2. #2 Re: Broken Rear Manifold Stud...
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    IT SUCKS!!! when it happened to me, i replaced the rear manifold. We tried to heat it, drill it, easy outs. replacing the whole thing was the easiest option
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  3. #3 Re: Broken Rear Manifold Stud...
    I live here. DirtDog's Avatar
    Jun 2012
    Razor blade is really the easiest way to get it out
  4. #4 Re: Broken Rear Manifold Stud...
    Banned
    Oct 2013
    Moorhead, MN
    There is no way in Hell I am taking the rear exhaust manifold off... From what I've seen, you should then start learning how to extract studs from engine blocks, lol.
    Plus, it's impossible to get back there.
  5. #5 Re: Broken Rear Manifold Stud...
    Jun 2012
    taking the rear manifold off really isn't that hard. spray the bolt with some liquid wrench and let set over night then spray again in morning then wait an hour and break the bolts loose. people take the rear manifolds off all the time to install headers
  6. #6 Re: Broken Rear Manifold Stud...
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Drill it all the way through with a concrete 3/8"drill bit and put a bolt and nut on it.
    Concrete bits have a carbide tip and will drill about anything.
    I broke mine at the crossover and in the head when I install my headers. It can be fixed but patience is a Must.
  7. #7 Re: Broken Rear Manifold Stud...
    May 2011
    Tampa FL near USF
    Quote Originally Posted by Twizted 1 View Post
    This is a good idea, we never thought to use a concrete bit, the bolt and nut was our original plan
    Or we can look as this as a good time to install some headers, Just like stated above soak the rear bolts in liquid wrench or PB blaster penetrating oil. then remove the front dogbones, then ratchet strap the motor forward to make plenty of space to reach the rear bolts.
  8. #8 Re: Broken Rear Manifold Stud...
    Jul 2013
    Summertown Tn
    Be sure to run the motor to get it hot before removing the bolts. Don't apply steady torque to the ratchet, use a quick pop of the ratchet to get the bolt to break free then take it out. I found out the hard way that steady torque will break the bolts off in the head.
    Good luck.
    Sent from my SGH-I747 using Tapatalk 2
  9. #9 Re: Broken Rear Manifold Stud...
    Banned
    Oct 2013
    Moorhead, MN
    I just thought of something...
    Shouldn't I be able to just put a nut on the back side of the stud, and hit it with my air ratchet until it pops out???
  10. #10 Re: Broken Rear Manifold Stud...
    Aug 2011
    'Merica
    make sure you go the right way
  11. #11 Re: Broken Rear Manifold Stud...
    Banned
    Oct 2013
    Moorhead, MN
    !!! You got jokes!!!
    =P
  12. #12 Re: Broken Rear Manifold Stud...
    Banned
    Oct 2013
    Moorhead, MN
    Is it a 13 or a 10?
  13. #13 Re: Broken Rear Manifold Stud...
    Banned
    Oct 2013
    Moorhead, MN
    Jk. 8mm.
  14. #14 Re: Broken Rear Manifold Stud...
    Jul 2013
    Summertown Tn
    Wishful thinking man. Although its a possibility it could work. Good luck.
  15. #15 Re: Broken Rear Manifold Stud...
    Cross over to rear manifold? Smack the stud downward (that's toward earth). The nut on the backside will break free and then just nut and bolt it back together.
    You're pretty good at breaking stuff huh? You are on the right forum.
  16. #16 Re: Broken Rear Manifold Stud...
    Banned
    Oct 2013
    Moorhead, MN
    I gots teh rawr.
  17. #17 Re: Broken Rear Manifold Stud...
    Banned
    Oct 2013
    Moorhead, MN
    I drilled, drilled, drilled, and then drilled for days.
    Finally I gave up and hired a mobile mechanic. $75 when he got it done.
    Popped out within 5 minutes of him drilling...
    Baby Jesus deserves to cry.
  18. #18 Re: Broken Rear Manifold Stud...
    LOL.. I had a similar issue when I got my first 3800. I tried it all, mechanic buddy stops over, takes the air hammer and in 45 seconds it popped.
  1. exhaust manifold stud
    By kurupt305 in forum General Tech Discussion
    Last Post: 07-16-2013, 08:43 AM
  2. rear cylinder head stud
    By Someone Much Cooler in forum General Grand Prix Discussion
    Last Post: 12-25-2011, 09:16 PM
  3. Broken lug nut stud replacement
    By rnovember in forum General Tech Discussion
    Last Post: 05-03-2011, 10:16 AM
  4. How to fix broken wheel stud?
    By ryangtp89 in forum Brakes/Suspension/Chassis
    Last Post: 10-08-2008, 10:59 PM
  5. rear wheel stud-how to get it out and new installed?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2008, 03:47 PM
