Thread: this might be a problem soon
Results 1 to 3 of 3
  1. #1 this might be a problem soon
    Ga
    Hay I have a 97' GTP and lately she has been giving some idling trouble and also trouble while I am driving. When a push the gas,i get slot o shaking and it feels as if my car is choking or something his holdong it back from letting loose. I am still able to drive it is getting worse , I need some help man.
  2. #2 Re: this might be a problem soon
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    welcome to the forums
    i'd post in the tech area in general for the best responce
  3. #3 Re: this might be a problem soon
    Wooster, Ohio
    Welcome, i'm also new to the forums but you should probably check your cat, do the old drill a hole in the exhaust before the cat trick, if it cleans up you know you need a new one. if not then weld the hole up and keep up your work
  1. A/C Problem
    By KSGTP97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2010, 08:55 AM
  2. Problem!
    By pure in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2009, 11:07 PM
  3. AC problem
    By MDCruzer in forum General Tech Discussion
    Last Post: 06-12-2009, 08:36 PM
  4. Might have a problem.
    By Pontiacman in forum General Tech Discussion
    Last Post: 12-26-2008, 08:57 PM
  5. What is the problem?
    By spidamanSS in forum General Tech Discussion
    Last Post: 05-07-2008, 12:56 AM
