Thread: Hello from Arkansas/Wyoming
Results 1 to 3 of 3
  1. #1 Hello from Arkansas/Wyoming
    ar
    Chats
    Hi, my name is James as you can tell, I am from Newport, AR. I am currently enrolled at Wyotech and will be graduating Dec. 18th. I have been through the auto core classes, I am now in Chassis Fabrication. I did have a 00 GT at one point and my mother has a 07 base model right now. I am a good personal friend with Jess (SlowM90), I have done some work on her car. I am really into drag racing. My grandfather was kinda well known for that back in the 60s, I have had several cars(ls1 f-body, slobalt ss, 23 t altered, several dsms) If you want to know anything else just ask.
  2. #2 Re: Hello from Arkansas/Wyoming
    Nov 2008
    Searcy,Arkansas
    Chats
    Bout time you join!
  3. #3 Re: Hello from Arkansas/Wyoming
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    Chats
    welcome
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  1. Only In Arkansas!!!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 08-22-2009, 11:06 AM
  2. Heads up to Kansas, Missouri, Arkansas
    Last Post: 05-10-2008, 09:25 PM
  3. Members in Arkansas
    Last Post: 03-03-2008, 10:04 AM
  4. Hello from the University of Arkansas
    By DanGTP in forum Introductions/Noob Questions
    Last Post: 02-22-2008, 12:34 AM
