Thread: New member with major Electrical problems. 2001 GT 3800 2 door
Results 1 to 14 of 14
  1. #1 New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    Afternoon! New to this site. From what I have read in this forum, it looks like you folks are well informed on the Grand Prix and is among the main reason for joining. Not sure if this is the correct location to start a new post but I an sure someone will let me know.
    I have a 2001 Pontiac Grand Prix Gt 2 door 3800 with 165,000 miles. The other day the radio quit working, I was riding shot gun and the wife was driving. I opened up the fuse panel to check the fuse and pressed on the panel and the radio started working. Well it lasted for one day. The next morning all was fine until I got gas. After filling up the tank, I started up the car but now the radio, power windows, power door locks, key fob, interior lights, temp display on the rear view mirror all stopped working. (The trunk would unlock on the key fob but nothing else) . A flashing "security light" now comes on (never seen this before). I checked the main fuses under the hood and fuses next to the glove box. All were good with 12 volts except for the radio fuse. There was no voltage but the fuse was good.
    I do not have a wiring diagram (this is the first major electrical problem this car has had (except for a mouse chewing through the alternator sensor wire, killing the battery about 6 months ago). We live in the county on a farm and mice are a problem.
    I am not up to speed on the major components this car uses for the electrical system but have tried the obvious checks. I have access to a brand new BCM but do not have the proper scanner tool to program it
    This almost sounds like a poor ground since there is voltage to the fuses. Is there a floating ground system in this car? The key has been sticking and now can be pulled out before it is turned fully off.
    Living on a farm, one has to learn how to repair almost anything at a moments notice.
    I was not able to "search" the fourm with any results. Is there a proper way to search?
    Any suggestions?
    Thanks in advance
    Farmer Bob
    What a way to start a new post with all of these problems
    New member with major Electrical problems. 2001 GT 3800 2 door Attached Images
  2. #2 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    May 2008
    Schuyler, NE
    Chats
    265
    Welcome Farmer Bob. Did you check the maxi-fuses under the hood as well? The big ones at the top of the fuse box.
  3. #3 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Apr 2015
    Columbus, OH
    Chats
    246
    Do you have any codes?
    Top Swapped 01 Imp
  4. #4 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    HUDSON
    Chats
    You have BAD "F'n" connections, start at your fuse box that magically starts working when you touch it. It could be bad grounds also, or broken/chaffing wires.
    The fuse box is going to have to be inspected closely to make sure everything is safe from short circuits.
  5. #5 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    Thanks for the reply. If you are talking about the main fuse box, I checked the big ones (60 amps) and they were all good with 12 volts. I also noticed that the (-) battery terminal was almost hot to the touch. I took both the (+) and (-) terminals off and found some rust under the (-) terminal. I used a round wire brush that attached to my drill and cleaned all of the terminals and hooked them back up. Same problem with radio, windows, etc.
  6. #6 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    Quote Originally Posted by QUICKSILVER462 View Post
    Thanks for the reply. It only worked that one time when I touched the fuse panel. I have tried to move it to gain access behind it but it's a tight fit. Is there a procedure on how to remove it without breaking anything. Not sure what you mean on the "F'n" connections. Is this the rear connections to the fuse box?
    BTW; What is the procedure to post pictures? When I click on the manage attachment icon a blank black box appears
  7. #7 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    Quote Originally Posted by bandook View Post
    I just checked this morning and there are no codes.
  8. #8 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Apr 2015
    Columbus, OH
    Chats
    246
    Quote Originally Posted by Farmer Bob View Post
    Dude, you've most likely got a short to ground. Your battery is not supposed to get warm terminals.
    Top Swapped 01 Imp
  9. #9 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    The (-) terminal was fairly rusty and not very tight when I touched it yesterday. I had been starting & stopping the engine quite a bit. After I cleaned the terminals and started it several times they did not get warm. I would not be surprised if there was some sort of short or open circuit somewhere - now only if I could find it!
  10. #10 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Apr 2015
    Columbus, OH
    Chats
    246
    Get a test light. Disconnect negative battery terminal. Clip one end of light to battery ground, other end to negative terminal. If light comes on u have a short. Start pulling fuses until light goes out. Then fix that circuit.
    Top Swapped 01 Imp
  11. Likes cheatah faheatah liked this post
  12. #11 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    The test light came on when I checked it last night. I also checked the amount of current draw there was and it measured 0.045 amps. I may be wrong but does the ECM, BCM, Clock always have a draw to power it's backup memory? I need to Google to find out what is normal drain if any at all.
    Our '97 Honda was next to the Pontiac, so as a test I checked to see if there was a drain with everything off and there was. It measured 0.029 amps
    It was getting late so I did not make any other tests. Plan on checking what circuits have this draw.
    Not having any luck getting fuse panel next to glove box loose enough to check behind it for loose connections or chafed wires. There are what look like two grey relays behind the glove box. Does anyone know what they control. I'll send some pictures of the relays tomorrow.
    Thanks for your help.
    BTY; Can one just rent a SCann II tool to check any on board error messages in the BCM and other components? It sure would save a bunch of time.
    Is there a site where one can get a wiring diagram for a 2001 Pontiac Grand Prix GT?
  13. #12 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    Update:
    While testing the various circuits for shorts and current draw while the key turned "on" I mistakenly jumped across what I think was the gray RAP relay (In the glove box area) causing the security light to start flashing. Now the car would not start. I did the Pass Key reprogram and nothing happened except the security light now stopped blinking. \
    I came across this procedure in this site:
    03-13-2011
    Ignore the install new computer and disconnect battery parts.
    1. Disconnect battery
    2. Install new computer
    3. Reconnect battery
    4. Put emergency brake on to disable daytime running lights (this step is required!)
    5. Make sure all doors trunk and hood are closed leave driver window down and reach in threw window
    6. Try to start. If it doesn't start, leave the key in the on position for 10 min on 97-03 cars and 15 min for 04 and newer cars. The security light should turn off after this amount of time.
    7. Turn off ignition for 3 seconds
    8. Try and start the car. It probably won't start. Repeat step 5 two more times.
    9. If this doesn't work disconnect battery for 5 seconds and then try and start the car.
    If that doesnt work, try this one:
    That did not work for my car but the procedure below worked!
    1. Disconnect battery for 10 sec.
    2. Reconnect battery
    3. Turn key to ON position
    4. Do not try to start vehicle, just quickly click to RUN position to engage security light
    5. Let vehicle sit with key ON for 35 min.
    6. Attempt to crank vehicle. Once vehicle is running, the security light may still be on
    7. If security light is still on, turn key to OFF position for 5 sec.
    8. Turn key to ON position and security light should turn off
    9. Start vehicle and enjoy new PCM
    Note: My security light did not come on during the 35 min test
    At least the car now runs again. The radio, windows, locks, interior lights, chime, temp display in rear view mirror still do not work.
    I pressed the "On Starr" power button and the welcome too On Star program came on through the radio (was able to change the volume but there was no light display in the radio )..After the introduction that was it!
    Any thoughts?
    SMGPFC Two Nipple General
  14. #13 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    [QUOTE=Farmer Bob;1498504]
    Any suggestions?
    Thanks in advance
    Farmer Bob
    What a way to start a new post with all of these problem\[QUOTE]
  15. #14 Re: New member with major Electrical problems. 2001 GT 3800 2 door
    Jul 2019
    Virginia
    Chats
    Update
    I would like to thank everyone who replied. I ended up taking this to a local shop that has the scanners & updated GM software. The new BCM I ordered was found to be defective. It so happened the owner of the shop has a 2001 Grand Prix 2 door GT with Identical options, He took his BCM & plugged it in and evertthing worked except the SRS (This was later found to have a defective control module). A replacement BCM was ordered, put in and the car is back on the road.
    The only problem is the radio display does not work. I will try searching this site to see if this can be repaired.
    Again, Thanks for all of the suggestions!
    Farmer Bob
  16. Likes bandook liked this post
  1. major problems 01 gtx
    By black01gtx in forum Introductions/Noob Questions
    Last Post: 01-15-2013, 09:15 PM
  2. Car. Went through MAJOR problems.
    By 94grandprixNOwhipple in forum General Grand Prix Discussion
    Last Post: 02-22-2012, 10:25 PM
  3. Major Electrical Problems
    By Lighty in forum General Tech Discussion
    Last Post: 12-13-2009, 01:46 AM
  4. Major Problems - Need help, please
    By dellfire in forum Off Topic Discussion
    Last Post: 11-04-2009, 09:37 PM
  5. Major Problems Please Help
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-11-2008, 08:52 PM
