Thread: 2008 grand prix major oil leak
Results 1 to 7 of 7
  1. #1 2008 grand prix major oil leak
    Nov 2013
    pittsfield ma. 01201
    Chats
    Pulled in driveway today low oil light came on no oil showing on dip stick oil sprayed on front of engine and inside fender well oil spot in drive way any ideas where to look for cause of leak
  2. #2 Re: 2008 grand prix major oil leak
    Chats
    83662
    Oil filter gasket or the oil pressure switch are the most common.
    Clean it up, add some oil then start it up real fast to see where it's spraying oil.
  3. #3 Re: 2008 grand prix major oil leak
    St. Louis
    Chats
    My bet is on the oil pressure sending unit.
  4. #4 Re: 2008 grand prix major oil leak
    Nov 2013
    Chats
    Thanks Buddy will check it out
  5. #5 Re: 2008 grand prix major oil leak
    Nov 2013
    Chats
    Thanks FordMan
  6. #6 Re: 2008 grand prix major oil leak
    Apr 2019
    Milwaukee
    Chats
    Quote Originally Posted by FordMan77 View Post
    I had this on a 3100 in a buick. Car leaked mildly forever, and then one day after an oil change it just puked oil all down the street, luckily I turned it off immediately and had it towed to the shop that did the change. (I was in an apartment at the time and didn't have access to DIY) I figured a filter gasket or something but no, the timing was coincidental, the sending unit which had been leaking all along just gave out and spewed oil. They replaced it and it didn't leak a single drop after that.
  7. #7 Re: 2008 grand prix major oil leak
    Nov 2013
    Chats
    Thanks Buddy for your input hope thats all it is will let you know after I change it
  1. 2008 Grand Prix 3.8 III Series Coolant leak
    By Fatesjoke in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2017, 08:29 PM
  2. Major Coolant Leak
    By Autoworks in forum General Tech Discussion
    Last Post: 03-13-2012, 12:23 AM
  3. 2008 grand prix
    By khayes in forum Introductions/Noob Questions
    Last Post: 05-27-2011, 06:34 PM
  4. Major oil leak!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2010, 11:47 AM
  5. New Here-2008 Grand Prix
    By aricshep in forum Introductions/Noob Questions
    Last Post: 09-17-2009, 10:59 PM
