Thread: Alloy wheel clear coat peeling
Results 1 to 9 of 9
  1. #1 Alloy wheel clear coat peeling
    Nov 2013
    pittsfield ma. 01201
    Chats
    The clear coat is peeling on one of my alloy wheels wondering if any one has any tips on removing the old clear coat and putting on a new coat
  2. #2 Re: Alloy wheel clear coat peeling
    Mar 2014
    Tucson
    Chats
    2468
    Can't help you with the application of new clear, but to get the old stuff off check out aircraft paint remover.
  3. Thanks daviddawg thanked for this post
  4. #3 Re: Alloy wheel clear coat peeling
    Apr 2014
    commerce twp,mi
    Chats
    Quote Originally Posted by daviddawg View Post
    im going to be tackling this on my '08s rims as soon as i get a few days of nice weather. using the aircraft stripper mentioned. not reclearing,thoughi im going to polish them and do the upkeep on em which isnt bad.
    i havent read or seen much success with reclearing aluminum rims. theres aluminum rims cleared from the factory all over metro detroit that show it doesnt work too good.clears seem to turn yellow over time or start peeling- the clear needs a scuffed surface to bite which that scuffed surface will show through the clear.
    IF you want to try it, clean thoroughly with a wax and grease remover, spray an adhesion promoter, then clear and NOT a spray bomb clear.
  5. #4 Re: Alloy wheel clear coat peeling
    Nov 2013
    Chats
    Thanks Buddy know where I can buy it at
  6. #5 Re: Alloy wheel clear coat peeling
    Nov 2013
    Chats
    Thanks for your help my friend
  7. Likes SaukRapids liked this post
  8. #6 Re: Alloy wheel clear coat peeling
    Apr 2014
    commerce twp,mi
    Chats
    should be able to pick it up at autozone or a local auto parts store. home depot or lowes also carried a paint stipper. just dont get the water based stuff.
  9. #7 Re: Alloy wheel clear coat peeling
    Nov 2013
    Chats
    Thanks again tomsteve
  10. #8 Re: Alloy wheel clear coat peeling
    Apr 2014
    commerce twp,mi
    Chats
    YW. what i have heard work good is powdercoating. prolly not worth it for one rim. even then the tires have to be popped off the rims, gotta find a powdercoating place and a set of rims/tires for a bit of the car has to be on the road.
    keeping polished rims up and shining doesnt require too much work after the initial buffing/polishing. i think im going to have quite a bit of work on mine. 110,000 of metro detroit driving on them. the inside of the rims are real nasty. im not going to polish the insides but will clean em up. outsides have that peeling to various degrees depending on which rim. id like to pop the tires off and remove the valves but that would take too much time and extra $$$ so just gonna do what i can.
  11. Thanks daviddawg thanked for this post
    Likes SaukRapids, daviddawg liked this post
  12. #9 Re: Alloy wheel clear coat peeling
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Chats
    1417
    Quote Originally Posted by tomsteve View Post
    Will this work on shiny aluminum wheels? I had steelies done last fall for the other car, so I know the course and cost. I looked up clear powdercoating a polished wheel and honestly couldn't find much. What I did read was inconclusive.
    If powder coating works for my polished 10 spokes, I'll def look into doing it again. Thanks
  1. Spoiler clear peeling
    By mngtp in forum Visual/Body Modifications
    Last Post: 07-11-2013, 07:04 PM
  2. Clear Coat or no Clear Coat???
    By Iceman6669 in forum General Grand Prix Discussion
    Last Post: 04-08-2013, 07:03 PM
  3. Is this clear coat?
    By PioneerGTP in forum Visual/Body Modifications
    Last Post: 10-04-2012, 10:35 PM
  4. clear coat
    By Logan541 in forum Visual/Body Modifications
    Last Post: 07-30-2011, 07:01 PM
  5. Clear coat leaving white spots on tinted tailights what clear coat would u recomend?
    By MattTheBaker123 in forum Visual/Body Modifications
    Last Post: 05-14-2010, 01:31 AM
