Thread: The E85 Thread... Questions and Answers
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 94
  1. #21 Re: The E85 Thread... Questions and Answers
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Chats
    3855
    Also you could use an afc2.x to reliability adjust for e85 on any setup.
    This. Easiest way to make tune go from gas to corn. change afc value/remove afc, fill back up with gas, put larger pulley on.
    04 GTP -HAI, 1.9 rockers.
  2. #22 Re: The E85 Thread... Questions and Answers
    Aug 2013
    Sandy, UT
    Chats
    3855
    Also, I vote for sticky.
  3. #23 Re: The E85 Thread... Questions and Answers
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Chats
    added a section about ethanol content changing throughout the year
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  4. #24 Re: The E85 Thread... Questions and Answers
    Mar 2014
    Cincinnati, OH
    Chats
    Quote Originally Posted by SnowTh1ef View Post
    That'd be awesome!
    2002 GTP sedan:
  5. #25 Re: The E85 Thread... Questions and Answers
    Mar 2014
    Cincinnati, OH
    Chats
    Also might want to add that stock injectors will support e50 on a stock tune reliability.
    Added to the tuning section
    2002 GTP sedan:
  6. #26 Re: The E85 Thread... Questions and Answers
    Banned
    Jan 2013
    maryland
    Chats
    Great write up!
    Sent from my LG-E980 using Tapatalk
  7. #27 Re: The E85 Thread... Questions and Answers
    Banned
    Jan 2013
    Colorado
    Chats
    88
    why is it possible to essenitally just run e85 on a basically stock engine on this car?
  8. #28 Re: The E85 Thread... Questions and Answers
    Banned
    Jan 2013
    maryland
    Chats
    I would..
  9. #29 Re: The E85 Thread... Questions and Answers
    Chats
    50094
    Quote Originally Posted by camopaint0707 View Post
    Almost any vehicle can run on E85 with just a few changes, key word being almost. The big oil companies make it seem like you need an entirely new car or you need to spend thousands of dollars to run E85. Even old carburated vehicles can be easily converted to E85, by just buying larger jets for the carb.
  10. #30 Re: The E85 Thread... Questions and Answers
    Banned
    Jan 2013
    Colorado
    Chats
    88
    what if i wanted to run a flex fuel setup though
  11. #31 Re: The E85 Thread... Questions and Answers
    Arizona
    Chats
    258
    I m not aware of any 3800 PCM that has flex fuel capibilty. The LS4's grand prixs can use a flex fuel sensor though.
  12. #32 Re: The E85 Thread... Questions and Answers
    Mar 2014
    Cincinnati, OH
    Chats
    Newer cars do this much easier, since they actually have a way to measure the ethanol content and adjust the ECU accordingly. We have to do this manually to the w-body platforms, as they were not equipped with the software or sensors at that time. Hence why one would have to manually check the ethanol content in a given tank of fuel, and then adjust the stoichiometric targets in the tune to really dial it in.
    Note that E85 is pretty forgiving though. As in even this coming winter, when it is more like E70, than E85, I will not change my tune. I will just let it run on the rich side for several months (unless I have some issues, which I would report to this thread if so!)
    2002 GTP sedan:
  13. #33 Re: The E85 Thread... Questions and Answers
    Feb 2009
    flintnasty MI
    Chats
    3989
    In theory i could build a flex fuel tune for 42# injectors. The stock 3800 ecu will fully support it without the need of a flex fuel sensor but i would need to do some testing and i would expect it to be limited to a specific OS for awhile.
  14. #34 Re: The E85 Thread... Questions and Answers
    Feb 2009
    flintnasty MI
    Chats
    3989
    And btw flex fuel sensors are old news. They are to expensive and offer little to no value in a modern car. Gm discontinued use of them years ago.
  15. #35 Re: The E85 Thread... Questions and Answers
    Arizona
    Chats
    258
    Some gm cars came with virtual flex fuel algorithims . in theory when the fuel trims go out of normal tolerance it references a sloped Afr target and adjust itself till it gets to a acceptable range. Which eliminates the need for any physical sensor however it never ended up working out for gm so they went back to the physical sensor
  16. #36 Re: The E85 Thread... Questions and Answers
    Mar 2014
    Cincinnati, OH
    Chats
    Interesting.. Any idea when they came out? I wonder why they didn't put them in the 97-03 GTPs! Wish we had them built in...
    2002 GTP sedan:
  17. #37 Re: The E85 Thread... Questions and Answers
    Feb 2009
    flintnasty MI
    Chats
    3989
    Gm has been doing flex fuel since at least 01... it is usually only offered as an option on their common fleet vehicles.
  18. #38 Re: The E85 Thread... Questions and Answers
    Feb 2009
    flintnasty MI
    Chats
    3989
    What cars went back to using sensors?
    Either way if they managed to make it work good enough before it would be good enough for the average gtp owner with a 15 year old car.
  19. #39 Re: The E85 Thread... Questions and Answers
    Arizona
    Chats
    258
    The later impalas, almost all their SUV's and other regular vehicles sold to the public not just fleet. They stopped for about 2 years iirc making flex fuel sensors and then staryed again. Also a a lot of the holden vehicles got them as well.
  20. #40 Re: The E85 Thread... Questions and Answers
    Feb 2009
    flintnasty MI
    Chats
    3989
    And guess what all those models can be commonly found as fleet vehicles.. woah
  1. Old Thread
    By SpeedGrid in forum General Grand Prix Discussion
    Last Post: 08-12-2014, 05:43 AM
  2. Replies: 3
    Last Post: 07-15-2013, 12:53 AM
  3. not your typical "runs for 3 seconds and dies" thread.
    By darkhorizon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 09:35 AM
  4. Can't post a New Thread in the "For Sale - Vehicles"
    By sandite5 in forum Off Topic Discussion
    Last Post: 06-04-2010, 05:30 PM
