Thread: Adding HUD and a DIC to your 97-03 GP
Page 1 of 9 123 ... LastLast
Results 1 to 20 of 167
  1. #1 Adding HUD and a DIC to your 97-03 GP
    SE Level Member $03gp/gt$'s Avatar
    Feb 2008
    Chillicothe/Peoria IL
    If your car didn't come with head-up display (HUD) or a Trip Computer AKAriver Information Center (DIC) and you want to put them in you can. If your car is in a model year before 2000 you probably have some or all of the plugs already in your dash, but if you have a 2000 or later GP you'll probably have to splice some wires.
    Splicing wires isn't hard to do, the DIC installation is easier since most of the wires are cut right off of the old DIC connector so it's just a butt-end connection that has to be made so if your nervous or are a beginner, start with this to get the hang of it before you tackle the HUD. Tapping into wires takes a little more skill but is still very easy. I use BackInBlack's twist 'n tape method and have had no problems whatsoever. He has a great page you can see here:
    DIC installation may be as simple as plug-and-play if you already have the harness, but if you don't, not to worry. Follow the wiring table below to splice in wires and you'll be up and running in no time. The DLC wire is the hardest one due to it's tight location, all the others are easy. The DIC is held in by clips on either side only, squeeze these and pull it out, there's some rattle insulator padding back there that it might be stuck to so you might have to wiggle it out.
    NOTE: If you have a 97, ONLY use a 97 DIC. It has the "Check Tire Pressure" light on it. No other year has this light. The 89-03 DIC's are all interchangeable. But you can't use a 97 DIC on a 98-03 either. I can't stress this enough, don't waste your money on a DIC that won't work. 97 DIC's ONLY work on 97's, 98-03 DIC's ONLY work on 98-03's and are interchangeable. Another note is that the GT DIC's and GTP DIC's are different. GT DIC's for 98-03 say "TRAC" on the right button, GTP DIC's for 98-03 say "TCS" on the right button. Try to get the correct one for your car (GT=TRAC, GTP=TCS) or you'll have issues with the "TCS off" indicator light being inverted. You can fix this by doing some extra work but who wants to do MORE work? Moral of the story...just buy the right one!
    DIC Wiring Diagram
    HUD installation is much more involved since you need to splice more wires, almost all of them will have to be tapped instead of butt-connected, and you have to cut the dash. If this scares you, good, that way you'll be more careful! All 97-03 HUD's are the same for both GT's and GTP's so there's no issue of fittment here. The only thing you'll have to watch out for other than if you have the plugs back there or not is the wire B4 on the instrument panel connector 1 which will be missing if you didn't have the plugs. This connector will light up the little gas pump symbol on the HUD when the low fuel light comes on in the dash. If you don't care about this, don't worry but if you want it to work, you'll have to steal one of the connectors out of the base DIC connector (same style) to clip into there so you can splice it. All other wiring is straight forward.
    HUD Wiring Diagram
    Cutting the dash will be easiest if you have a dremel tool. Watch your window when your cutting, I nicked mine and there's an inch long etch mark right in my field of view . You'll have to get the appropriately coloured dash piece from someone, remove the front piece by carefully prying up all along and pulling up and out. You'll lose some clips...hopefully your HUD piece has them all still. Lay the HUD dash piece over where it clips into the dash and draw a close outline around the piece in fromt of the driver with white chalk. Take the dash peice out and draw another line about an inch inside of this line. You can now do anything you want to the dash inside the second line because you know it'll be covered by the dash piece. Cut out the dash roughly in the shape of the pics below, keep a rag or shopvac nearby, it's messy business. You'll have to punch holes and cut some of the dash pad out from around the three areas where the clips closest to you pop into. Be careful here as well as cutting out space for the harness since these are the two areas that come closest to the edge of the dash piece. You don't have to cut the trim right along the bottom of the windshield but there will be a clip that the part you're cutting out is attached to that will be a pita to get out. Clip the HUD in (don't worry about putting the front screws in, they're not needed), clip the switch in, turn your car on, and test it all out (speedo, dim, up/down, turn signals, radio, CD, high beams) to make sure everything's good before you clip the dash piece on.
    Here's a little pic of some images I pulled out of a search:
    1, 2: Factory plug locations (approximate)
    3: 3 clip holes for the HUD dome clips
    4: outer line
    5: inner line
    6: factory hole (pic is stretched vertically)
    7: HUD in cut hole
    8: Done
    Installation Pics
    There you go...you've completed the HUD and DIC installation primer. Now do a little more searching if you have any other questions. You can also email or PM me as per the details on the bottoms of the wiring tables. The tables in this post will always be the most current of any one you'll find since I'll be reposting them here any time there is a change. Just a couple more tips; don't rush, and MAKE SURE you don't have the stock plugs in there before you start splicing.
    Thanks, and good luck B)
  2. #2 Re: Adding HUD and a DIC to your 97-03 GP
    Oklahoma
    Because this is a great write up I moved this rather than delete it, but please read:
    http://www.grandprixforums.net/f14/a...ad-6828-2.html
    I appreciate your work on this and for putting this all together. Great work.
  3. #3 Re: Adding HUD and a DIC to your 97-03 GP
    Feb 2008
    Thanks for moving this for me I didnt realize that I posted in the wrong section until it was to late.. lol
    Thanks
  4. #4 Re: Adding HUD and a DIC to your 97-03 GP
    Oklahoma
    Its not a big deal. It happens.
  5. #5 Re: Adding HUD and a DIC to your 97-03 GP
    Oklahoma
    Also, can you fix the hyperlink after the second paragraph, its not working.
  6. #6 Re: Adding HUD and a DIC to your 97-03 GP
    Apr 2008
    eBay Motors: Pontiac Grand Prix 97-03 Driver Information Center DIC (item 120337275116 end time Nov-27-08 10:48:44 PST)
    This one says it was pulled from a '98 and has the "Check Tire Press" light on it. Would this not work in my '97? If not, where could I find one?
  7. #7 Re: Adding HUD and a DIC to your 97-03 GP
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by Guitarist575 View Post
    i have a 1997 DIC if your interested...
    by the way this is an awesome write up, now what about adding HUD to a 2004 Grand am Gt? lol
    COMP G
  8. #8 Re: Adding HUD and a DIC to your 97-03 GP
    Feb 2008
    Man I will see what I can come up with for you on that and pm it to you...
  9. #9 Re: Adding HUD and a DIC to your 97-03 GP
    SE Level Member robertrod's Avatar
    Jan 2009
    Dallas, TX
    Any info on installing a HUD on a 94 grand prix se 3100 ?
  10. #10 Re: Adding HUD and a DIC to your 97-03 GP
    May 2008
    on a 98 gt where should the harness be for the HUD switch? it was dark, but nothing was obvious, just a metal piece behind the cubby hole....
  11. #11 Re: Adding HUD and a DIC to your 97-03 GP
    Apr 2008
    Ok I just installed my ('97) DIC (already had the harness in there) and it's really DIM! And now my radio is too! Any ideas?
  12. #12 Re: Adding HUD and a DIC to your 97-03 GP
    May 2008
    does your say trac or tcs?
  13. #13 Re: Adding HUD and a DIC to your 97-03 GP
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    So if i have a 2001 GP GT with the non-digital DIC i can add in a Digital DIC? and i just need to make a few splices?
    SPREAD THE JAM
  14. #14 Re: Adding HUD and a DIC to your 97-03 GP
    Apr 2008
    Quote Originally Posted by MNGP07 View Post
    The old one said trac. I can't read the new one (or the radio) because there is no backlight.
    My radio still has no backlight even when I reconnect the old DIC
  15. #15 Re: Adding HUD and a DIC to your 97-03 GP
    SE Level Member StreetChariot's Avatar
    Cowtown, OH
    Quote Originally Posted by redprix View Post
    You mostly will splice wires...
    The following wires can be spliced from the non-digital DIC:
    Left Door
    Right Door
    Rear-Left Door (if 4dr)
    Rear-Right Door (if 4dr)
    Trunk
    Washer Fluid
    Dimmer
    If not a few more (it's been a while)
    You'll have to wire into the VSS line to pull the Speed Data for the millage/oil/etc.
    Search on Google for: Digital DIC conversion Grand Prix
    I believe AutomotiveForums has the diagrams still:
    http://www.automotiveforums.com/t765...onversion.html
    Last edited by StreetChariot; 04-08-2009 at 02:51 PM. Reason: Adding link with diagrams
  16. #16 Re: Adding HUD and a DIC to your 97-03 GP
    London, ON
    Nice to see this is making its way around the net to help everyone out. Here are my original posts of this writeup which may have some additional information including working images:
    Ontario Quebec Club Grand Prix • Login
    ClubGP Message Forum troubleshooting
    Thanks,
    Pete
  17. #17 Re: Adding HUD and a DIC to your 97-03 GP
    Donating Users kind153's Avatar
    Pittsburg, KS
    question...
    Does anyone know why I'm getting flashing zeros?
    I've been searching and searching but couldn't find any viable solution.
    I suspect that the data is not being supplied (or not correctly supplied), but at where is it not getting enough information?
    I checked tan wire from DLC-9 and dark green from back of speedometer, they all check and are connected from their sources to the soldering point of the pins.
    Even tried connecting scanner to the OBDII port and no codes, it does connect.
    It's 98 GP GT, and the digital dic I bought off the ebay is supposed to be from 1999 GP as well.
    (Does HUD have to be present by any chance??)
    Any, I mean ANY, ideas please!!
  18. #18 Re: Adding HUD and a DIC to your 97-03 GP
    SE Level Member Blacknight02GT's Avatar
    Feb 2009
    Buffalo,NY
    I just got my DIC in off of ebay, and It didn't come with any wires or any wires attached to it. Will i need those? or is there a connector already in the dash somewhere for it? Any help is much appreciated!
    2002 Grand Prix GT (K&N + Ram Air = BEAST)
  19. #19 Re: Adding HUD and a DIC to your 97-03 GP
    Apr 2008
    Quote Originally Posted by Blacknight02GT View Post
    No, your car will probably come with the connector. If not, there are instructions above that tell you which wires to use.
    BTW anyone that my able to help. I STILL have the problem I posted about above... About my new DIC knocking out my radio backlight. I haven't had time to work on it. Wondering if anyone has any suggestions?
  20. #20 Re: Adding HUD and a DIC to your 97-03 GP
    Pittsburg, KS
    Have you checked all the wirings? In my case all color didn't match 100%, kinda had to guess, especially dimming wires..
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Thinking about adding a turbo
    By MS1227 in forum Turbo
    Last Post: 12-13-2008, 04:22 PM
  3. adding gauges
    By keenan00gtp in forum Visual/Body Modifications
    Last Post: 10-12-2008, 11:48 PM
  4. news question about adding performance shift
    By abuckley1290 in forum General Tech Discussion
    Last Post: 07-16-2008, 11:56 PM
  5. Adding acetone to gasoline
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2008, 01:24 PM
