Thread: Make A 4" Fenderwell Intake (FWI)[*]
Page 8 of 10 FirstFirst ... 678910 LastLast
Results 141 to 160 of 199
  1. #141 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Quote Originally Posted by dbrincefield View Post
    will this same set up work on an 03 Monte Carlo SS?!?
    The same idea should work, the exact measurments might not be the same, you will just half to test fit, and build your own. pick up a 3" to 4" rubber reducer, and a 45*-4" elbow, and some 4" pvc, and try.
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  2. #142 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member dbrincefield's Avatar
    Feb 2010
    Dayton
    alright thanks man!!
  3. #143 Re: 4" Custom FenderWell Intake
    lagrange,Georgia
    are you still online?
  4. #144 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Canada
  5. #145 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Pennsylvania
    ZZP dyno tested it and recorded half a horse loss when using that.
  6. #146 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member MakeitLouder97's Avatar
    Maryland
    I was thinking about doing a FWI but people have said that they decrease gas milage, and I am worried about hydro lock.
  7. #147 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Feb 2009
    Red Deer AB
    Most cars drop 1 - 2 mpg, some even increase mpg.
  8. #148 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Maryland
    I'm sure this sounds like a dumb question but why would your gas milage drop
  9. #149 Re: Make A 4" Fenderwell Intake (FWI)[*]
    MO
    colder air means there's more oxygen in it. In order to the the air/fuel ratio correct, and since you're running richer air, then you must run richer fuel.
    <brandonl2000> LMAO D!!
  10. #150 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Maryland
    It still doesnt make any sense one person on this thread said they got a improvement in gas mileage why would it improve gas mileage in one case and decrease it others
  11. #151 Re: Make A 4" Fenderwell Intake (FWI)[*]
    MO
    because every car runs different and is in a different environment. According to my principal, sucking in hot air would give you better gas mileage, but i still dropped with a short ram. Either way, we're talking about 1 mpg.
  12. #152 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Feb 2009
    Red Deer AB
    and yes, the person that said they had an increase was running a short ram, which is hot air. fenderwell is cold air.
  13. #153 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Canada
    Where did most of you buy your cones and what kind??? also do you have to use a 7" or can it be shorter?
  14. #154 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Banned
    Mansfield, Ohio
    Here's my intake, quite easy to do, very simple. Cost me $66 out the door with a $10 off coupon from advance. It's 4 inch tubing with a 45 degree bend, I tried the 22.5 degree bend but the filter was to big and was hitting I believe the cruise control. I bought one 3.5 to 4in coupler, bought a 7/8's holesaw bit for IAT, came with the grommet. K&N filter 4x9 inch very pleased. I actually saw on the butt dyno you can def feel the difference. Supercharger screams like a baby. I also had a old 45 degree elbow and since my car is a 98gtp I already had the triangle duct where the guys use the roof flashing. I attatched the 45 degree bend on the inside of the fenderwell to duct cold air right to the tip of the filter.
    Pic quality sucks, cell phone pic but you get the general idea.
  15. #155 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Feb 2009
    Red Deer AB
    The elbow in the fender will do nothing unless you have it all the way to your fog light housing and made a ram air or something. you would be better off just opening up that little triangle area to let more air thru.... but anyways all you have is a short ram, which is hot air, and yes it will be loud, the s/c whine that is.
  16. #156 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Maryland
    my crappy intake plan on redoing it soon
  17. #157 Re: Make A 4" Fenderwell Intake (FWI)[*]
    Grand Rapids, MI
    are there photos of the fender bracket once the bumper is removed that i will be cutting?
  18. #158 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member gpaddictiongtp9798's Avatar
    Jun 2010
    elmwood park, il
    my problem with this whole thing. the measurments for the roof flashing were no where close and i mutilated the first roof flashing and have to do it over again tomorow. and yes getting the pvc into the 90 degree elbow small side is not that easy after 2 hours of messing with it and cutting open my hand. im going to try again tomorow and see how this turns out. only thing i changed is i painted the pvc pipe blue to just have a different look.
  19. #159 Re: Make A 4" Fenderwell Intake (FWI)[*]
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    after all that mess with the flashing and everything, I just switched mine over to short ram. The filter was getting rediculously dirty being right next to the road. It's much easier now I can't really tell a difference on the butt dyno.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  20. #160 Re: Make A 4" Fenderwell Intake (FWI)[*]
    SE Level Member NewBoost1997's Avatar
    Jul 2010
    Minnesota
    What do you do about the computer? My computer is inside the air box....
  1. Make a difference section
    By LowlyfeGTP in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 03:15 PM
