Thread: rear end swap
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: rear end swap
    Apr 2013
    Suffolk, VA
    Chats
    Ummm... 3 personal friends of mine have autos, and the 1 we are selling at the GM dealership I work at is an auto. I have seen more auto WS6 cars than 6-spds so.... yea.
    I can start pulling production numbers if you want.
    Actually... just in 02 its about half and half. Click here
    Trust, its based on options. WS6 has nothing to do with motor/trans codes.
    Wow, Thats alot more that I wouldve thought. I personally never seen an auto WS6. Didnt think people getting the WS6 package would want an auto over a manual Granted im sure most of them came from the factory like that.
  2. #22 Re: rear end swap
    I live here. TLSheff's Avatar
    Chats
    Honestly I don't understand why anyone would want a auto muscle car. It takes all the fun out of driving IMO, look at the Viper, never had an option for a Auto trans and it's sold plenty of numbers over the years.
    But it wasn't up to me lol
  3. #23 Re: rear end swap
    Apr 2013
    Suffolk, VA
    Chats
    I agree. Autos can be fun, IF and ONLY IF they are 6 speed and shift quickly and have the right gear ratios. The 4 speed GM throws in everything is a slush box with crap for gear ratios.
  4. #24 Re: rear end swap
    Because Firebird Govna47's Avatar
    May 2011
    Oak Ridge
    Chats
    716
    yes well, The trans was already sold, so I can't has cheezburger
    2001 Pontiac Firebird 3.8L V6 - now accepting donations for new rear end - woot
    Why There's a Firebird Invading your Zone
    2001 Ferd Exploder Sport 4.0
  5. #25 Re: rear end swap
    Chats
    I sowy!!!!
    now that that's over, go find another one. GO!
  6. #26 Re: rear end swap
    May 2011
    Oak Ridge
    Chats
    716
    I'm too lazy
  7. #27 Re: rear end swap
    Chats
    Then you should at least put a v8 in it.
  8. #28 Re: rear end swap
    May 2011
    Oak Ridge
    Chats
    716
    you buyin'?
  9. #29 Re: rear end swap
    May 2011
    Oak Ridge
    Chats
    716
    Getting back to the original point of this thread...
    Quote Originally Posted by philbar71 View Post
    The biggest thing is to check which kind of rear end your car has now (3 or 4 channel) and make sure it matches the rear thats from the WS6. If not, then its a bit of a hassle to keep the ABS/TCS.
    Now how big of a hassle are we talking about here?
  10. #30 Re: rear end swap
    Apr 2013
    Suffolk, VA
    Chats
    It depends on what your car has. If you have a 3ch axle (ABS only) and you want to swap in a 4Ch axle you either have to drill a hole in the top of the axle housing and install your ABS sensor out of your old rear or connect only one wheel speed sensor to the ABS. The 4ch rears have two wheel speed sensors (one on each axle shaft) as opposed to a 3Ch rear with only one speed sensor (on top of the diff in the housing).
    To keep it simple, get an axle that matches your car. And make sure it has a limited slip (Auburn or Torsen is fine)
  11. #31 Re: rear end swap
    May 2011
    ohio
    Chats
    I was looking to pick one up for my boy's first car.
    1998 - 2002 Camaro or Firebird. Anyway, do any companies make any aftermarket suspension regarding comfort and performance for these cars?
    I hear these things ride rough.
    Anybody have info on a 5.3 V8 to swap into one? Please let me know. It would be an awesome surprise.
  12. #32 Re: rear end swap
    Chats
    Quote Originally Posted by itsCOMPlicated View Post
    Not that we support suggesting other forums, but since you are going to hijack the thread for your own. You'd likely better off searching through a F-body forum (LS1Tech) for these types of questions. The aftermarket is vast for them, but few people on this forum will know where to go or how to do the swap.
    What I do know is, don't bother with a 5.3L swap, go for a LS1 5.7 swap. The change over is better and you'll have to get a LSx intake to fit, and you'd want the additional power.
    Now back to rear ends.
  13. #33 Re: rear end swap
    May 2011
    Oak Ridge
    Chats
    716
    I'll try to throw the car up in the air and take a look at what I've got going on down there. hopefully it won't be too much trouble
    but then again, it is a GM soooooooo
    I'll buy some beer first
  14. #34 Re: rear end swap
    Apr 2013
    Suffolk, VA
    Chats
    Quote Originally Posted by Govna47 View Post
    Well its simple to find out if you have a 3ch rear or 4ch rear. Do you have TCS? If so then you have a 4ch rear, if not then its a 3ch. And swapping the rear isnt hard at all. I did it with my dad one saturday morning and was done before lunch time.
  15. #35 Re: rear end swap
    May 2011
    Oak Ridge
    Chats
    716
    Got under and looked at it today. Been real busy and finally had a free night. Turns out what I've got is still pretty gorgeous, so I'm going to try and modify it instead of buying a whole new rear. Sadly, I'll save more money in the end for other things...Like a V8 :P
  16. #36 Re: rear end swap
    May 2011
    Oak Ridge
    Chats
    716
    nevermind....Picking up the new rear Saturday
  17. #37 Re: rear end swap
    Apr 2013
    Suffolk, VA
    Chats
    Good luck with the swap! Its pretty straight forward. If you arent doing it on a lift then Id recommend leaving the wheels on while taking the old one out as it makes it about 1000 times easier to get it out from under the car.
  18. #38 Re: rear end swap
    May 2011
    Oak Ridge
    Chats
    716
    I bet it would. I hope everything goes smoothly
  1. Replies: 20
    Last Post: 03-26-2013, 11:05 AM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. Help rear head gasket swap
    By shihiran in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2010, 04:04 PM
  4. 98 grand prix rear head cylinder swap
    Last Post: 05-27-2010, 12:10 PM
