Thread: O0 GTP boost gauge not working?
Results 1 to 3 of 3
  1. #1 O0 GTP boost gauge not working?
    Apr 2018
    Wastelands of NJ
    I'm not a mechanic so bear with me. I have a beater 00 GTP that I'm trying to resurrect and the latest glitch is I see no boost building on the gauge when I accelerate. Any thoughts?
  2. #2 Re: O0 GTP boost gauge not working?
    Mar 2018
    NY
    Are you actually getting boost & just no readout on the DIC? You would know if you are or not just by the seat of your pants
  3. #3 Re: O0 GTP boost gauge not working?
    HUDSON
    Even thought you may not be a mechanic, you may want to open the hood and check all your vacuum lines to make sure they are all in place, and not disconnected or broken. There should be a sticker under the hood somewhere that has the vacuum hose routing, if it has not been removed or covered with dirt, you should be able to follow it. It is common for a car this old to have broken or cracked original vacuum hoses, the hard plastic ones turn brittle and fall apart very easy after 19 years of under hood heat.
  1. boost gauges not working? and no boost at full throttle
    By jeannelle101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2016, 11:23 AM
  2. low voltage maf code and half working boost gauge?
    By 00Daytona in forum General Tech Discussion
    Last Post: 08-07-2014, 12:39 PM
  3. boost gauge not working
    By Adasm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2012, 09:57 AM
  4. boost gauge/meter not working
    By shart in forum General Tech Discussion
    Last Post: 01-28-2012, 06:06 PM
  5. Boost Gauge Stopped Working
    By chipsdubbo89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 03:58 PM
