So, I am starting a new thread for my coolant issue...Swore I had it fixed. new water pump/coolant elbows/upper heater core fittings.
Everything seemed fine last night and this morning. I got home tonight and noticed antifreeze PUDDLE more towards the drivers side.?! I cannot see any dripping/leaking from above anywhere. The passenger side of the engine where I did all the work is not leaking. it appears to be coming from the transmission/engine meet up area and hitting the oil pan and dripping off the oil pan lip from about an inch away from the flywheel/flex plate. it does also seem to be dripping off the engine higher up somehow and hitting the transmission pan as well in about the same area. however, shinning a light up in between the trans and oil pan/block, the block appears to be dry. (not much room to get in there with anything to see real good).
my fear is head gasket. my hope is a LIM. but I should be able to see that up top right?! anything else I am missing or not thinking of?!
