Thread: ABS Light On and Traction Control Off 2002 Grand Prix GT
Results 1 to 10 of 10
  1. #1 ABS Light On and Traction Control Off 2002 Grand Prix GT
    SE Level Member Musclecarguy's Avatar
    London
    I have a 2002 Grand Prix GT and it's been acting weird lately. Every so often I'll be driving along and the ABS light will come on along with the TCS off light. And it stays on until I turn my car off. Soon as I turn it off and back on it is back to the way it was before with no lights on. It has done this probably 3 or 4 times in the last week. Any help is appreciated.
    2002 Grand Prix GT (Push button start system, LED Tail lights, Flowmasters with Oversized dual round SS Tip, K&N Air Filter, Custom Projector Headlights with LED strip and HIDs, HID Fogs, 18" Chrome rims with Continental Extreme Contact DW summer tires, and a loud sound system) DD
  2. #2 Re: ABS Light On and Traction Control Off 2002 Grand Prix GT
    Omaha, NE
    It sounds like a bad wheel hub assembly sensor. If that's the case, you can't just replace the sensor, the whole hub assembly has to be replaced.
  3. #3 Re: ABS Light On and Traction Control Off 2002 Grand Prix GT
    Apr 2014
    CT
    make sure the harnesses between the lower control arm and the steering knuckle is ok first before you go tearing out wheel hubs. The wires like to break in that high stress area.
  4. #4 Re: ABS Light On and Traction Control Off 2002 Grand Prix GT
    London
    If it broke wouldn't the light be on constantly?
  5. #5 Re: ABS Light On and Traction Control Off 2002 Grand Prix GT
    Omaha, NE
    A bump or turn could kick it the connection loose. Since it is coming on after driving for a bit, my guess would be that it's not reading the same speed as the other side.
    That being said, a rare possibility would be that the vehicle speed sensor is having problems. Usually anything abs and trac will be hub though.
  6. #6 Re: ABS Light On and Traction Control Off 2002 Grand Prix GT
    London
    I have already replaced the hub assemblies all around. 1 of them for a second time. Now that I think about it it seems to be after a bump that the light comes on
  7. #7 ABS Light On and Traction Control Off 2002 Grand Prix GT
    Find a local shop that can scan for abs codes and they should be able to tell you where it's coming from.. Could be a defective hub or wire connection. Either way don't assume just because the hubs been replaced that they are ok lord knows our hubs tend to have constant issues.
    04 Comp G.
  8. #8 Re: ABS Light On and Traction Control Off 2002 Grand Prix GT
    SWPA
    If it is only intermittent it sounds like a cracked wire going to the hub. As RED said, get it scanned to see which hub is the one causing the issues then check it out.
  9. #9 Re: ABS Light On and Traction Control Off 2002 Grand Prix GT
    GT Level Member mainecrab's Avatar
    Feb 2008
    Mine did that when it went bad. It would only come on sometimes intermittent when I hit a bump or something. Then go off when the car went off then later come on when I hit a bad area coming home from work. Seems like it starts with intermittent then gets worse where it stays on all the time.
  10. #10 Re: ABS Light On and Traction Control Off 2002 Grand Prix GT
    Apr 2012
    Goderich, Ontario
    My car recently started doing this as well. However, mine only comes on when I spin the tires.
    -Paul Walker
  1. Tmy Traction control light comes on Grand Prix 2005
    By ccoimbre in forum General Grand Prix Discussion
    Last Post: 10-17-2015, 10:32 AM
  2. 2002 Grand Prix MPG improvement and Check Engine Light gone!!! fixed by chance
    By mtsav8or in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2011, 11:21 PM
  3. ABS and traction off lights are on- 98 Grand Prix GT
    By mistymcd in forum Introductions/Noob Questions
    Last Post: 04-21-2010, 07:32 AM
  4. 04 grand prix traction control/ABS
    By mrmorris in forum Introductions/Noob Questions
    Last Post: 11-14-2009, 10:17 AM
  5. 2004 Grand Prix GTP ABS and Traction Control
    By jrjess in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2009, 06:50 PM
