Thread: How difficult is it to replace front lower air deflector?
Results 1 to 17 of 17
  1. #1 How difficult is it to replace front lower air deflector?
    Oct 2012
    USA
    It is the big piece of plastic air dam thing under the radiator. I saw a thread in "how to" section but it seems the post was lost. I have bump this plastic thing several times and there are several cracks on it. It seems it is just bunch of push-in retainers and bolts from my brief inspection but I am not sure if there are other things that hold it in place. How difficult is it to replace it? Do I have to take other things off in order to replace this air deflector?
    In case you want to know, the part number is 15246564. My car is a 05 grand prix base.
    Thanks!
  2. #2 Re: How difficult is it to replace front lower air deflector?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    No it's pretty straight forward, just a few bolts and plastic retainers like you said. I had mine off a few months back to make more room for an AC compressor swap on my 06.
  3. #3 Re: How difficult is it to replace front lower air deflector?
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    From the picture on ebay, it looks to be very similar to the one on my '03 in the way it goes together. I pulled my off and put it back on. If you can get your jack your car up in the air to get a little room to get some maneuvering room; it should be three just 10mm bolts and those push-in retainers; there is one that is up in the front point that's a pain the rear, but not overly complicated.
  4. #4 Re: How difficult is it to replace front lower air deflector?
    Jul 2012
    Chicago
    If you don't have a jack or ramps, drive one side of the car onto a curb. More room to work. Other than that, should be an easy swap.
    -Carl
  5. #5 Re: How difficult is it to replace front lower air deflector?
    Oct 2012
    USA
    Thank you all for the replies! Great to know it is an easy job. It seems one or two push pins in the front are a little hard to access but other than that, it seems pretty straight forward. I will try it and report back if I have encounter any difficulties.
  6. #6 Re: How difficult is it to replace front lower air deflector?
    May 2008
    Winnipeg, MB
    Take it off and leave the space empty so you got nothing to damage in the future.
    2007 Pontiac Grand Prix
    Ohio
    If you mean the air deflector then you need to leave it there.. They are there for a reason.
  8. #8 Re: How difficult is it to replace front lower air deflector?
    Jul 2012
    Chicago
    I haven't had mine on for over a year, and you can definitely feel the difference on the highway.
    -Carl
    Quote Originally Posted by tod1d View Post
    No. It's there to help air flow.
    04 Comp G.
  10. #10 Re: How difficult is it to replace front lower air deflector?
    Oct 2012
    USA
    Quote Originally Posted by nos4blood70 View Post
    I am curious about difference. What difference do you feel? Is it a difference in temperature (car runs a little hotter without it?) or car performance? I read somewhere that the air deflector help direct the wind to cool the radiator more effectively.
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by Coldwaves View Post
    Its to push air up to the radiator. When I had the Camaro I took it off and regretted it. The car would run hot/over heat when cruising.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
    Correct
    04 Comp G.
  13. #13 Re: How difficult is it to replace front lower air deflector?
    Oct 2012
    USA
    Quote Originally Posted by Sandman View Post
    Thank you for the explanation! I bump the lip of the deflector a few times and there are several cracks where the lip bend. It is still holding there. I am wondering if it worth replacing it.
    It's probably fine if anything I would take it out and get some plastic weld and fix the cracks and call it a day. Cheap fix > buying a new one from dealer.
    04 Comp G.
  15. #15 Re: How difficult is it to replace front lower air deflector?
    Jul 2012
    Chicago
    Actually my car runs perfectly fine without it. Right at 180*. My front end seems a bit more floaty without it at speeds above 65 MPH. But this could be because my car is a Bonneville. H-body are different design than W-body. But then again I could be wrong.
    -Carl
  16. #16 Re: How difficult is it to replace front lower air deflector?
    Oct 2012
    USA
    I totally agree. Since this piece is not supporting or standing a lot of force, I guess gluing them or weld them will probably do the job. I will try the easiest thing to use glue or epoxy without taking it out to see if it will work. Lining the big piece back and dealing with those rusted nuts and U nuts are not that easy when you have to lie down and work in small space.
    Thanks a lot for your information!
  17. #17 Re: How difficult is it to replace front lower air deflector?
    Oct 2012
    USA
    Maybe it is the difference in design. I have seen a couple of posts saying the engine runs hotter without the deflector. Maybe different car relies differently on those deflectors. Anyway, as long as it does not overheat, I guess it is OK.
    I remember I also read somewhere that those air dam help reduce the amount of air going through the underside and direct the air flowing more through the upper. This will help the traction and stabilize the car. I am not sure how significant it is. It is hard to believe but it might be actually true. I remember I once watched a F1 race on TV. The spoiler of one car fly off and the car immediately lost traction. I can never imagine the importance of such a small piece if I did not see it.
  1. How to replace front hubs
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 03-12-2015, 11:18 AM
  2. How difficult is it to upgrade/replace lifters?
    By nik12937 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2012, 06:29 AM
  3. 04+ lower air deflector part number
    By gpse2000 in forum Visual/Body Modifications
    Last Post: 04-02-2012, 05:04 PM
  4. front air deflector
    By Stock4now in forum Visual/Body Modifications
    Last Post: 10-12-2011, 07:42 AM
  5. Tie rods/ Lower Control Arms - replace them all?
    By 86Sierra in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2009, 10:04 PM
