Thread: Blower Motor or Blower Motor Resistor???
Results 1 to 5 of 5
  1. #1 Blower Motor or Blower Motor Resistor???
    SE Level Member soverstreet4472's Avatar
    Jun 2012
    Samson, Alabama, United States
    I have a 99 grand prix se 3.1
    when i used to turn the air/heat on it randomly made a growling type noise then stopped. But If i turn it to the defrost setting and on #1 or #2 it warms the car from the dash but not the vents. nothing blows out of the actual vents. what could it be? blower motor? resistor?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Sounds like a blower motor to me.. I'd start with that if it was making noise
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Blower Motor or Blower Motor Resistor???
    Jun 2012
    how do you tell if its the motor or resistor?
    Oct 2011
    MI
    Well motor will typically just stop working. Especially if it was making a growling noise.
    Resistor packs usually go out in different fan modes. Ex. 1 &2 don't work but 3 & 4 does. Sometimes they all go out but high is a separate relay that powers the fan it bypasses the resistor entirely.
    If u have a volt meter you can probe the two wires going into the fan motor if there's voltage when you have the fan on then it's the blower motor. Sometimes you can wack them and they will temporarily work.. also you can drop the blower motor and see if you can physically move the blower cage if it's seized there's your answer.
  5. #5 Re: Blower Motor or Blower Motor Resistor???
    Feb 2010
    TN
    I had the same thing it was the motor
  1. Blower Motor Resistor
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 02-28-2014, 05:34 PM
  2. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  3. blower motor resistor
    By hacket in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2010, 11:40 AM
  4. The Old and The New, Blower Motor Resistor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-29-2008, 12:31 PM
