Thread: KR under full throttle
Results 1 to 20 of 32
  1. #1 KR under full throttle
    GT Level Member Twist's Avatar
    Jul 2011
    Kitchener
    getting a bit of KR when wot when easing into boost, highest ive seen it get is 6.4, using a aeroforce gauge to monitor car wasnt showing any kr till couple days ago colder weather have any effect?
    mods are
    L36
    ZZP Z7 Turbo Kit
    Liquid/Air Intercooler
    HV3 Insert
    42# Injectors.
    currently running 9lbs
    Tuned by Overkill
    wheres the best place to start?
    2009 Rabbit
  2. #2 Re: KR under full throttle
    Jun 2011
    Detroit, MI
    downpipe!
    iLoveSpade
  3. #3 Re: KR under full throttle
    Out West
    Add more fuel in transitional from stoich to PE.
    Whine with your Cheese?
  4. #4 Re: KR under full throttle
    Out West
    Quote Originally Posted by Hippo Machine View Post
    downpipe!
    Please just go away.
    Ohio
    Those 42s aren't maxing out are they? What about fuel pump?
  6. #6 Re: KR under full throttle
    Buffalo
    post scans!!
  7. #7 Re: KR under full throttle
    Quote Originally Posted by crazyguy03 View Post
    post scans!!
    This.
    And dea god how do we get Hippo to stop with these possibility posts?
    Ohio
    This.
    Kill it with fire
  9. #9 Re: KR under full throttle
    Jul 2011
    Kitchener
    how do i post the scans?? (might be a newb question lol)
    car also started reading a few misfires, going to do plugs and try to get ahold of a tuner
    any ideas what else could be causing the knock, it rly came out of no where, car was running amazing
    also did a TCC solenoid engine light went off but came back on reading same code
    starting to think its the tune?
    2009 Rabbit
    Ohio
    Could be false maybe? How are your motor and trans mounts? Uppers?
  11. #11 Re: KR under full throttle
    could be the mystical "bad gas"
  12. #12 Re: KR under full throttle
    Jul 2011
    Kitchener
    all mounts are looking good, checked everything over when the solenoid was done, ive ran 2 full tanks thru the car since it started, nothings changed, any suggestions, checkin all the plugs tomorrow
    2009 Rabbit
    Ohio
    Umm any exhaust clamps coming loose?? The downpipe mainly. Fuel filter? It's not catted is it?
    Ohio
    Yeah definitely check those plugs.
  15. #15 Re: KR under full throttle
    utah
    Start with plugs fo sho. Check injectors, fuel pressure....the list goes on really. Scans would help immensley
  16. #16 Re: KR under full throttle
    Jul 2011
    Kitchener
    everything looks fine, rly starting to think its false
    2009 Rabbit
  17. #17 Re: KR under full throttle
    utah
    Check the secondary 02 to see if its smaking the tunnel...also start shaking things....see what's loose
  18. #18 Re: KR under full throttle
    Jul 2011
    Kitchener
    only time the cars showing kr now is between shifts and even then its all over the place
    2009 Rabbit
  19. #19 Re: KR under full throttle
    Jul 2011
    Kitchener
    been all thru this car cannot find anything, bad fuel pump? again the KR is completly eratic, seein it at all throttle positions, spikes right at the end of a gear then drops then spikes, has to be fake just cant figure out whats causing it!?! getting ahold of a buddy that tunes soon , doing ls6 springs this weekend to so going to double check everything again and replace both knock sensors, then go crazy lol
    2009 Rabbit
  20. #20 Re: KR under full throttle
    Test the pressue at the rail?
    See if it is bleeding off by chance.
    From what I hear turbo cars get pretty thirsty for ze fuel...so you might try a re-wire before going into a pump.
  1. full throttle problems
    By scotty455 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2012, 09:11 PM
  2. Full Throttle Problems?
    By scubasteve in forum Introductions/Noob Questions
    Last Post: 02-29-2012, 04:42 PM
  3. trans sitting in 1st under full throttle
    By reem98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2011, 10:32 PM
  4. Does your nuts increase FULL THROTTLE by 50%?
    By NegativeOne13 in forum Off Topic Discussion
    Last Post: 07-26-2011, 10:23 AM
  5. Weird noise under full throttle
    By RegorHtims in forum General Tech Discussion
    Last Post: 11-11-2010, 12:52 PM
