Thread: Trans coolers
Results 1 to 19 of 19
  1. #1 Trans coolers
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Alright, I've been looking at transmisson coolers at autozone. They listed two different options. They have trans oil coolers and just trans coolers. So what's the difference? or are they the same? here is a link. the trans oil cooler is under "parts" and the trans cooler is under "accessoreis".
    Search Results for trans cooler | AutoZone.com
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: Trans coolers
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Same thing... Size is really based upon what it's needed for but a little overkill isn't bad, especially if keeping the one in the radiator functioning.
    Good opportunity to whore my car out... Here's my daisy chained 16,000lbs GVW coolers ran independent of the radiator. I welded studs on the bumper support to hang them. It's way overkill and I'll be putting a t-stat on it before next winter so the fluid won't be too cold.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: Trans coolers
    Jul 2011
    Michigan
    I found this one at advace auto, but it says for trucks and vans. so my question is, can to big be bad? here it is.
    Buy Imperial Econo-Kool® Transmission Oil Cooler 242016 at Advance Auto Parts
  4. #4 Re: Trans coolers
    Feb 2010
    Oklahoma City, OK
    Are you bypassing the radiator? Hopefully your not trying to tow, right? Is the car moded or stock? Driven hard? Etc....
  5. #5 Re: Trans coolers
    Jul 2011
    Michigan
    i would like to bypass the radiator. I'm top swapping my 97GT, and since it has the 4t60e I'm going to use a trans cooler. only difference will be a little higher compression, other than that its a stock GTP. I talked to a guy who turbocharged his monte with the same trans. Lasted over 100,000 miles with way more power then im looking at. He recommended a trans cooler.
  6. #6 Re: Trans coolers
    Nov 2011
    NY
    Maybe I'm wrong, but I thought you really don't need this for these tranny's unless you're got a trailer attached to the GP... Heat isn't an issue with these tranny's.
    Correct me if I'm wrong...? Just trying to prevent wasted money = no return...
  7. #7 Re: Trans coolers
    Heat can become an issue.
    But the only way to tell is to monitor your trans temps.
    If they get more than 10* higher than your ECT, you might want to consider an external.
    And the biggest key to cooling is ensuring all of your duct pieces are intact and functioning correctly.
    If not, you could have the biggest rad you can fit in there, and still overheat.
  8. #8 Re: Trans coolers
    Nov 2011
    NY
    Good to know, I thought the GTP's were ok as they already are hooked up to the Rad/cooling no? Are the GT's different?
    Thanks
  9. #9 Re: Trans coolers
    They both have tranny coolers in the rad.
    But if you're running a stall or very high power levels then you're much more likely to need the help.
    Otherwise, you should be fine.
  10. #10 Re: Trans coolers
    Jul 2011
    Michigan
    Matt. Would you recommend me getting one to help prolong the life of my tranny (hopefully itll be fine for a few months with easy driving)? and if so, is there such thing as to big, like the one i posted?
  11. #11 Re: Trans coolers
    Monitor temps.
    Then decide.
  12. #12 Re: Trans coolers
    Nov 2011
    NY
    Gotcha, thanks!
    Actually now that you mention the high speed stall converter it make s sense, didn't think of that cause I'm all stock... lol
  13. #13 Re: Trans coolers
    Jul 2011
    Michigan
    will something like the scangauge2 show trans temps?
    ScanGaugeII : Linear Logic - Home of the ScanGauge
  14. #14 Re: Trans coolers
    Feb 2010
    Oklahoma City, OK
    I'd just slap a 12,000GVW on her and call it a day. That's what most tranny shops here do, in fact a warranty card I had from one states that if you don't bypass the radiator and run an external cooler it voids the warranty.
  15. #15 Re: Trans coolers
    Jul 2011
    Michigan
    what should i use to monitor my temp though? the scanguage, or should i just buy a pillar and wire guages up? And will the scanguage monitor those temps?
  16. #16 Re: Trans coolers
    it should.
    Problem with coolers without t-stats is that the fluid may not warm up enough.
    Thats what combining the rad and the tranny cooler solves.
    Helps warm up the tranny fluid.
    Raises an interesting point: even if your engine coolant is warm, your engine oil isnt.
    Even if your engine oil is, your tranny fluid isnt.
  17. #17 Re: Trans coolers
    Texas
    Quote Originally Posted by BlackGT97 View Post
    Why yes it does:
    85 Corvette
    01 TA
    03 Z06
  18. #18 Re: Trans coolers
    Jul 2011
    Michigan
    Quote Originally Posted by txslow6 View Post
    Why yes it does:
    sweet. so your gonna sell me yours right? lol. ill look into getting one. Know if anyone is getting rid of one?
  19. #19 Re: Trans coolers
    Texas
    They are fairly cheap. I got mine from Autozone and it was around $160. My only complaint is that it can't data log. Other than that it's pretty badass.
    85 Corvette
    01 TA
    03 Z06
  1. Police Package 91C Coolers etc
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 01-28-2013, 02:33 AM
  2. For those with aftermarket/Aux. trans coolers...
    By Wotgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2011, 03:18 PM
  3. need advice about trans coolers.
    By kirkkarem1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2010, 04:40 PM
  4. Tranny coolers
    By hypnos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 05:50 PM
  5. Transmission Coolers for the Middle East
    By Panzer4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 07:49 PM
