Thread: Any DIY Step By Step to Change spark plugs??
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 83
  1. #41 Re: Any DIY Step By Step to Change spark plugs??
    GT Level Member GtpKo's Avatar
    Best place on Earth
    If they're that hard to get off, wear gloves or you'll get a busted knuckle. And the first time I changed the plugs in my car, I didn't know what I was doing and rocking the engine forward really helped me figure it out. Take out those dog bone bolts and push the car forward and step on the e-brake to hold it there. Not necessary but a help for the first time.
    Last tune-up I did, I put on some MSD wires with nice little plastic numbered rings on them so you know which wire goes where on the coil pack. From the top down, its 6,3,2,5,4,1. For the cylinder numbers, from the left to right in the front, its 1,3,5 and rear(by the windshield) left to right, its 2,4,6.
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  2. #42 Re: Any DIY Step By Step to Change spark plugs??
    GT Level Member ill12will8's Avatar
    DC/MD
    yea i already have the replacements. well imma start bright and early cuz now my car is sitting in the driveway with no front manifold, crossover or front plugs
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
  3. #43 Re: Any DIY Step By Step to Change spark plugs??
    Pennsylvania
    Shake them like they owe you money.
  4. #44 Re: Any DIY Step By Step to Change spark plugs??
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Ok so im gonna just go ahead and change my wires cause hell it cant hurt right? Any thoughts on which ones? I like OEM but with something like wires which I think could dictate a little performance id like to learn a little more.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  5. #45 Re: Any DIY Step By Step to Change spark plugs??
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    Quote Originally Posted by h0wl0ngcanitbe View Post
    This is a somewhat subject topic. In a nutshell, OE or OE equivalent wire will do the job just fine. I went with the Delphi made (who made the OE) version. Look very much the same, plug numbers in the wire, cut to length. Think I paid like $36 for the set. You can easily pay 5 times as much for wire, but you'll need wire holders as well and they will be a little more difficult to run due to thickness. So IMO, for these cars not being heavily modified the OE is the more practical choice.
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  6. #46 Re: Any DIY Step By Step to Change spark plugs??
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Quote Originally Posted by Gorecki View Post
    I just want to make sure Im reading this right. you only need wire holders for the fancy ones correct?
    silver 2003 Grand Prix GT List is on it's way to be updated
  7. #47 Re: Any DIY Step By Step to Change spark plugs??
    Nov 2010
    Maryland, US
    Quote Originally Posted by kjohnson View Post
    Correct! The wire comes in thickness rated in mm and larger wire (more expensive) will not fit well in the OE wire holders (harnesses).
  8. #48 Re: Any DIY Step By Step to Change spark plugs??
    I live here. TLSheff's Avatar
    Quote Originally Posted by SlowNA06 View Post
    plugs: $45
    wires: $30
    Time: 1 hour ($90)
    Total: $165
    $275/hour for labor? Fvuck that.
    GM AcDelcos are slightly more expensive, at least at the dealership I work at...
    GM#19171849 WIRE KIT, SPLG (ACDelco #726RR) - $69.50
    GM#12568387 SPARK PLUG, (ACDelco #41-101) (IRIDIUM) - $9.76(each) $58.56 for 6
    And $80 per hour for labor but even at 2hrs labor time for BOTH that would be $160 so your looking at $288.06 +tax so say $300 total, but still... when you can buy the stuff, buy good tools to do it right and bond with your car on a free saturday, for LESS.... why pay it? That's why I do MY OWN work on my car, unless its major and I don't have all the tools our techs do.
    Bottom line, if your not comfortable with learning what to do (considering at one point NOBODY around this forum knew what to do) let the dealership do it for you, otherwise just read, learn, and save $$$. Basic mechanics is something EVERYONE should know. I've always been the kind to say if you cant change a flat, rotate tires, and do basic maintenance, you shouldn't be driving.
    We WILL help with anything, you just have to ask and let us help you
  9. #49 Re: Any DIY Step By Step to Change spark plugs??
    Pennsylvania
    Okay, yeah, the dealership has a 40% markup over auto parts stores (or 80% over lowest cost online vendors).
    Regardless, I would consider any professional mechanic incompetent if he could not change the plugs and wires in an hour, though I admittedly don't know dealership flat-rates... it very well could be 2 hours. But "John Doe Automotive" definitely won't go flat-rate and some won't mark (as much) up on parts.
    Moot argument though, since we're working towards turning these fellas into backyard mechanics. "One of us," as the saying goes.
  10. #50 Re: Any DIY Step By Step to Change spark plugs??
    DC/MD
    i gots them b!tches out and the new ones it and she purrs like a kitten
  11. #51 Re: Any DIY Step By Step to Change spark plugs??
    Nov 2010
    Maryland, US
    Quote Originally Posted by ill12will8 View Post
    Someone put a tick mark on his man card, he be jammin!
  12. #52 Re: Any DIY Step By Step to Change spark plugs??
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    i just grab the metal boot with a pair of pliers and pull them off makes it easy and for a cheap alternative to acdelco u can use autolite tr55s had them in my gt and they worked good
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  13. #53 Re: Any DIY Step By Step to Change spark plugs??
    May 2011
    Brampton, Ontario, Canada
    So no pictures then eh?
  14. #54 Re: Any DIY Step By Step to Change spark plugs??
    Feb 2010
    TN
    It is completely unnecessary to remove your dogbones and rock your engine to change your spark plugs (though it can be helpful). I have enormous hands and thick forearms and have no trouble changing my plugs with the following procedure, which does not involve engine rocking:
    Make sure your engine is cold. I can't stress how much is sucks to do this on a hot engine. Pro Tip: park the passenger side up to a curb so you can stand on it if you're short.
    Pop the hood and stand on the passenger side of the engine bay. Unplug all of the spark plug wire boots from the spark plugs. If you're going to change the wires for fresh ones, just rip them off like an animal. Otherwise, you can kinda jiggle and twist and pull. Just let the plugs hang there.
    Assemble your socket wrench/knuckle/socket into Voltron. The tiger head hands really help with grip in this situation.
    Lean over (don't be afraid to brace yourself on the body of the intake manifold, but be very, very careful not to lean on anything plastic because you will break it) and use your hand on the socket to guide it to a spark plug. Sometimes, you'll accidentally find one of the exhaust manifold bolts... it's okay, because you won't be able to get those off with that socket. You can use your ~*IMAGINATION*~ to locate them if you like - just look at the front spark plugs and form a picture in your mind of the probable location on the other side. Anyway, contort your body into whatever position is comfortable - it is impossible to see what you're doing, so it doesn't matter where your head faces.
    Once you've got the spark plug loose, you can thread it out by hand by using a secret kung-fu grip. A dropped plug will go (almost) directly to the ground within arm's reach, so don't poo yourself if you drop it.
    Then get the other two. You will use various yoga poses in this - the squealing pig, fist-in-a-cookie-jar, and the majestic mantis-ape are among the most useful.
    If you can't get the front three out without further instruction, carefully, but forcefully shove the socket wrench (now Voltron) in to your ear until it protrudes from the other side of your head.
    Use a gapping tool to set the proper gap on the new spark plugs to 0.60. Begin re-insertion with the rear plugs. You may need to first find the hole with your bare finger (teehee) because by now, you've forgotten where that sucker is. Using your hand, get the plug mated up to the hole (giggle) and very carefully thread it in, being careful not to use excessive force to crossthread the plug, because that'll ruin your day.
    Get all three rear plugs as tight as you can with your fingers, then use Voltron to tighten them up pretty nice. Technically, you could use a toque wrench here once it's pretty tight, but I have no idea what to set it to because nobody ever bothers with that.
    Anyway, do the front three the same way, except you're allowed to use your eyes.
    As for the spark plug wires, I recommend removing them one at a time and then replacing them before moving on to the next wire, which ensures that you don't connect the wrong coil/cylinder combo - a magical treat that would make your engine breakdance. Oh, and the plugs just pop off those coils. Nothing special there.
    Questions?
    I have done this job many times and you are right I have never rocked the engine forward its more trouble then its worth only thing I would add is to use a fender protector cause it is real easy to scarpe a belt buckle on it and ruin a paint job
  15. #55 Re: Any DIY Step By Step to Change spark plugs??
    Pennsylvania
    Good thinkin'! Or, take off your pants.
  16. #56 Re: Any DIY Step By Step to Change spark plugs??
    Nov 2010
    Maryland, US
    I understand lovin a car but isn't that just a bit much?
  17. #57 Re: Any DIY Step By Step to Change spark plugs??
    May 2011
    I know this is an old post, but I'm kind of in a jam here. I took the dog bones off but the engine moved backwards (making access to the spark plugs even HARDER). Now I can't get the holes to align with the bolts. Can anybody help?
  18. #58 Re: Any DIY Step By Step to Change spark plugs??
    set your e brake, don't start the car, but put the car in neutral, that should free it up for you.
  19. #59 Re: Any DIY Step By Step to Change spark plugs??
    Nov 2010
    Maryland, US
    Also, rocking the car forward taking up the transaxle play and using the ebrake or tire stops to keep it forward. I found if possible parking it on a slight down hill makes this easier.
  20. #60 Re: Any DIY Step By Step to Change spark plugs??
    May 2011
    Thanks for the help guys. I kinda went into panic mode when I posted that message. It was my first time doing the spark plugs on this car, and it was a real pain. I had read earlier posts about removing the dog bones. I forget who it was (and I'm too lazy to scroll up...hee hee) but somebody said there was no need to remove the dog bones. I should have followed his/her advice. But when I looked at the back of the engine I thought to myself : There's no way I can do this with such limited visibility.
    So I removed the dog bones and wow, that made things MUCH MUCH WORSE. The engine slipped backwards giving me even less visibility. I stood there for like a minute and like 10 seconds later that's when it hit me. I actually said "Son of a *****" out loud.
    My neighbour to the right heard this, he starts to laugh and he introduces himself (I've only been at my house for a little over a month now), He walks over, asks what happened, I told him and he assesed the situation. My neighbour to the left was also out. He overheard us and he walked over. They both grabbed one side and started to pull forward as I slid the bolts in. Both guys were very kind; apparently they're family. LOL.
    So....I changed the plugs, but now.....I'm noticing that the engine is making like a funny sound like it's struggling. I double checked the order of the wires and that they were secure. So.....I'm a bit confused.
    One of them looked at it and said it appears to be coming from the belt. But, that sound never happened before so.....I'm a bit lost. Any suggestions????
  1. How to change the back 3 spark plugs
    By fremmy182 in forum General Tech Discussion
    Last Post: 06-19-2013, 04:13 PM
  2. First step!!!
    By htown se in forum Introductions/Noob Questions
    Last Post: 03-31-2010, 12:07 AM
  3. how to change the spark plugs
    By RedBarron in forum Introductions/Noob Questions
    Last Post: 02-25-2010, 05:35 PM
  4. Next Step?
    By Bunique7 in forum General Tech Discussion
    Last Post: 08-13-2009, 10:09 PM
  5. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
