Thread: Fuel trims
Results 1 to 8 of 8
  1. #1 Fuel trims
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Okay well ive always seemed to have a problem with my fuel trims. I dont have any vacuum leaks so I'm thinking its something else. At idle my ltft's are anywhere from +14 to +16. But as soon as i start accelerating they jump down to +3 to +5 . Could it just be a bad tune? I have an intense pcm btw
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: Fuel trims
    if youre sure you dont have any vac leaks it might be the tune. however, there are other things that can create high fuel trims.
  3. #3 Re: Fuel trims
    Bastard Reptile's Avatar
    Kansas City, MO
    Many stock MAF tunes can have crazy wacked out fuel trims. I've started on cars that were +12's in the winter.
    If you're sure that you don't have a vac leak (which would point to the +16 almost any time), then the tune is just that far off.
  4. #4 Re: Fuel trims
    Wilkes Barre, PA
    I mean i know that the maf screen is removed.. would that mess up anything?
  5. #5 Re: Fuel trims
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you have a vac leak, scan idle air counts
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: Fuel trims
    put it back in and see what happens. its not a restrictive part and its only job is to keep laminar flow across the MAF.
  7. #7 Re: Fuel trims
    Hagerstown,Md
    Also if you have a 2001 and new GP and no rear 02 that could cause the issue aswell. But Im still 99 percent thinking vac leak
  8. #8 Re: Fuel trims
    Wilkes Barre, PA
    well i know my evap system isnt working so idk if thats affecting anything.. I'll have to pick up a screen for the TB from the junkyard because i wasnt the one who took it out
  1. door trims rust, chips?
    By Ninny in forum Detailing Tips and Tricks
    Last Post: 01-18-2010, 07:58 PM
  2. Help with fuel trims
    By 00gpgtp in forum PCM Tuning
    Last Post: 01-10-2009, 11:48 PM
  3. Jacked Up Fuel Trims w/Scan
    By Lawngoose in forum PCM Tuning
    Last Post: 11-18-2008, 11:15 AM
  4. VE Tuning and Reseting Fuel Trims
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 07-07-2008, 01:34 AM
