Thread: PCM programming
Results 1 to 4 of 4
  1. #1 PCM programming
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I'm doing a top swap on my 97 SE 3.8 from a 97 GTP. I'm also swapping the transmission and the wiring harness. So essentially, except for the block, I would have a GTP under the hood. I'm doing a top swap instead of an engine swap for the experience and to make sure the gaskets are all sound. So, are there things in the PCM that deal with the engine block(compression ratio, etc) that need to be set or would I be just fine using the stock GTP PCM?
  2. #2 Re: PCM programming
    the GTP PCM should work for getting the car running and at least driveable. however, the tune is going to be way off and will need a considerable amout of work to run well.
  3. #3 Re: PCM programming
    Lakeside Park, KY
    So you're saying I should go ahead and have it tuned.
  4. #4 Re: PCM programming
  1. PCM Programming.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-15-2010, 04:01 PM
  2. Issue Programming New Key 04 GP
    By wizsap in forum General Tech Discussion
    Last Post: 02-15-2010, 07:36 PM
  3. Key Programming
    By designsquire in forum General Tech Discussion
    Last Post: 07-28-2009, 08:42 PM
  4. Programming
    By Jerime in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2009, 07:10 PM
  5. Programming my Key FOB
    By Keet04GTP in forum General Tech Discussion
    Last Post: 09-06-2008, 12:42 PM
