Thread: Traction control, stability control , abs brakes warnings
Results 1 to 6 of 6
  1. #1 Traction control, stability control , abs brakes warnings
    pa
    i have a 2006 grand prix gxp 5.3 v8. the TRACTION CONTROL, STABILITY CONTROL , ABS BRAKES WARNINGS all come on at the same time. i shut the car off and it was ok for a while then they came back on. what could cause this?
  2. #2 Re: Traction control, stability control , abs brakes warnings
    abs sensor in the wheel bearings are teh not working.
    Could just be a connection issue though.
  3. #3 Re: Traction control, stability control , abs brakes warnings
    pa
    i noticed this happens at slow speed when turning the steering wheel
  4. #4 Re: Traction control, stability control , abs brakes warnings
    pa
    thanks will check it out
  5. #5 Re: Traction control, stability control , abs brakes warnings
    to be sure you need someone with a scanner that can scan ABS codes.
  6. #6 Re: Traction control, stability control , abs brakes warnings
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    might be a short in the fusebox. tcs and abs all run off the same relay in our cars (power for the relay that is). but i'm an 02 and don't have stability control.
    <MiZzBeCcA>its not rape if you yell suprise
  1. traction control
    By rodburner in forum General Tech Discussion
    Last Post: 07-06-2011, 08:38 PM
  2. Traction Control
    By Dewey1964 in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2010, 11:06 PM
  3. traction control
    By 04muscle in forum General Tech Discussion
    Last Post: 01-17-2010, 02:18 AM
  4. Traction Control
    By tynev7 in forum General Tech Discussion
    Last Post: 08-18-2009, 10:55 PM
  5. ABS/Traction control
    By holsports in forum General Tech Discussion
    Last Post: 03-22-2009, 11:32 AM
