Thread: DIY Air Intake
Results 21 to 40 of 49
  1. #21 Re: DIY Air Intake
    Long Island, NY
    will do, im assuming biggers better so more air flow ect. , I am going to buy the parts soon, i should be able to find the pipes and everything at a pep boys or auto zone? and i noticed in someone elses post that they had pvc pipe it looked like, should i go with metal or pvc?
  2. #22 Re: DIY Air Intake
    Willoughby, Ohio
    it doesnt matter what material just as long as it 4in in diameter, which brings me to say idk if pep boys will have 4in piping, a filter and coupler maybe.
    but only 1 way to find out!
  3. #23 Re: DIY Air Intake
    SE Level Member PonchoMuscle's Avatar
    Telford, PA
    Here's pics of the FWI I fabbed up yesterday. I need to get some sheet metal screws to attach the roof flashing to the fender and it will be complete.
    It was super simple to make and it outperform any short ram aka "hot air" intake. Do yourself a favor and either do a FWI or if you insist on a short ram intake atleast build a box around it so the hot engine bay air doesn't get sucked in.
    I bought:
    1. 3" PVC - $5 at Lowes
    2. Roof Flashing - $4 at Lowes
    3. 7" K&N cone filter off ebay for $40
    Total = $49
    I shoved the PVC onto the stock elbow all the way up to where it is smooth so those restrictive ripples aren't being used. I had to cut a little out from the fender bracket in the fender well so the filter would fit in there but no big deal. You then cut the roof flashing to shape and slide in onto the PVC. The IAT gets plugged into the stock location and your done, super easy and effective. There are no harsh bends, a direct path of airflow and a filter that is blocked off from the hot engine bay. I noticed an immediate gain in torque throughout the low-end to midrange and the intake is now loud as hell. The cars exhaust note sounds a little more brawny, overall the best $49 I spent on a mod on any car.
    '97 Firebird Formula WS6 - 20,000 Orig. Miles - 11.47 at 119mph w/ 1.57 60'
    '03 Grand Prix GT L.E. - The bad weather DD
    '06 Harley Davidson XL1200C - The nice weather DD
  4. #24 Re: DIY Air Intake
    Willoughby, Ohio
    not bad for a cold air intake, essentially you 'bypassed' the restrictive part of the intake. it may not be the best looking but this is a good cheap and effective solution for a CAI
  5. #25 Re: DIY Air Intake
    Telford, PA
    Quote Originally Posted by CTKGP09 View Post
    Yeah I agree, I wouldn't do it on a show car because the PVC will make it look "cheap" but for a car like mine that is a beater DD it's great.
  6. #26 Re: DIY Air Intake
    Willoughby, Ohio
    and a little paint goes a long way
  7. #27 Re: DIY Air Intake
    Telford, PA
    I'm afraid that paint will flake off the PVC or so I've heard?? I was going to pick up some dark blue spray paint I need regardless and it would match the car and look pretty nice...
  8. #28 Re: DIY Air Intake
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    If you scuff up the PVC tube w/ sand paper before painting it might stay on there better
  9. #29 Re: DIY Air Intake
    Willoughby, Ohio
    sand, prime, paint, clearcoat for best results
  10. #30 Re: DIY Air Intake
    Trevose, PA
    Alright so here is the new list for my intake, let me know what you all think:
    Spectre 9732 Filter- Spectre Performance 9732 - Spectre Performance Air Filters - Overview - SummitRacing.com
    Spectre Chrome 4" 45° Tube- Spectre Performance 9749 - Spectre Performance Modular Air Intake System Adapters - Overview - SummitRacing.com
    Spectre 4" Coupler (red)- Spectre Performance 9772 - Spectre Performance Silicone Coupling Adapters - Overview - SummitRacing.com
    I have the dark green color on my GP GT so I think the red will look good under the hood
    Might eventually paint the brake calipers red
  11. #31 Re: DIY Air Intake
    Willoughby, Ohio
    perfect! thats a big filter too, you like the results of this setup
  12. #32 Re: DIY Air Intake
    Trevose, PA
    Will there be any performance gain or more just the sound will be different?
    Either way I'm doing it lol
    Also, do you know what the difference between stock spark plugs and the big 10.3 red ones they sell at zzp are? I asked the question in another thread and just got linked to the safely modding your 3800 thread where it does not answer my question
    Thanks for all your help CTKGP09
  13. #33 Re: DIY Air Intake
    Long Island, NY
    with the links you posted above 2000grandprixgt are you going to have it put together like this? 45 degree arm -> coupler -> filter?
  14. #34 Re: DIY Air Intake
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Quote Originally Posted by mk frilla View Post
    No.
    He'll do it like this:
    Throttle Body -> Coupler -> 45 degree arm -> Filter
    The filter has a clamp on it already and it will hold onto the 45* pipe. You then attach the coupler to the pipe and Throttle Body. .....just like CTKGP09's picture above. The coupler is blue, the pipe is green and the filter is the maroon
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  15. #35 Re: DIY Air Intake
    Long Island, NY
    thanks alot, like i said im completely new to this just trying to do it right the first time and not screw it up, thank you for helping explain it.
  16. #36 Re: DIY Air Intake
    Willoughby, Ohio
    Quote Originally Posted by 2000GrandPrixGT2000 View Post
    you will feel a little more power, hear more sound, and get 1 or 2 MPGs. its a good investment
  17. #37 Re: DIY Air Intake
    Long Island, NY
    ctk, in the photo above it doesnt show where you put the sensor on the pipe, or did you leave it unplugged, because my grand prix has a sensor attached to the stock intake pipe, does anyone have any links to pipes that have holes pre made if theres such a thing?
  18. #38 Re: DIY Air Intake
    Trevose, PA
    I too am curious about where his AIT sensor is
  19. #39 Re: DIY Air Intake
    Telford, PA
    If you have a 1/2" drill bit you can go ahead and put the IAT wherever you want/it will fit.
  20. #40 Re: DIY Air Intake
    Willoughby, Ohio
    ^^^ right like underneath the pipe, might have to extend the wired tho
    mine is kinda thrown in and clamped through the coupler but sticks straight up so it still gets airflow
  1. 4'' intake on an 04?
    By gpgt04 in forum 04+ Specifics
    Last Post: 11-14-2009, 04:15 PM
  2. 3.1L Intake
    By josemolina2008 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-26-2009, 02:32 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. Intake
    By bct717 in forum 04+ Specifics
    Last Post: 03-22-2009, 09:41 PM
