Thread: Engine mount question
Results 1 to 5 of 5
  1. #1 Engine mount question
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Ok, so i have this vibration at about 60-70 only when i accelerate.The vibration goes away when i coast in neutral.My CV axels are 1 year old, my hubs are new, and the car has just been aligned. Could worn motor mounts(upper or lower) be the culprit? (tires are new falkens that are balanced) Any feedback would be great, thanx
  2. #2 Re: Engine mount question
    lower mounts might cause this, but normally it is an axle problem. assuming those are actually good since they are new, i would think the mounts would be next.
  3. #3 Re: Engine mount question
    GT Level Member Deviq's Avatar
    SE WI
    Hate to revive an old thread but I'm having the same problem. Did the lower mount fix the vibration for you and how did you get access to the mount? Ya ya.. I'm a noob.
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  4. #4 Re: Engine mount question
    Gotta jack it up...yank off the tire and probably the plastic flashing that covers the balancer. You'll wanna loosen the 15mm nuts under it and on top of it...(so 4 in total)...then jack up the transmission with either a special trans jack (if you have one) or center a decent 2x4 on your jack and ease it up on the trans pan till you notice the engine has moved enough to remove that mount. If they are factory, look for gunk and fluid build up...kinda like CV grease. The factory ones are fluid filled and crack and leak all the hydraulic fluid out and basically become a pile of rubber pieces...aka...trash. You can get solid rubber non-fluid filled replacements from AutoZone on the cheap...and you'll never have to worry about them again.
  5. #5 Re: Engine mount question
    SE WI
    Thanks blue! I also searched right after posting and found the how-to on it. Guess I got a little excited to find someone with the same type of problem.. lol
  1. Could it be an engine or tranny mount?
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2010, 11:12 PM
  2. Gxp engine mount replacement
    By tfro in forum 5.3L V8 (LS4)
    Last Post: 08-21-2009, 06:41 PM
  3. lower engine mount?
    By RichCresci in forum General Tech Discussion
    Last Post: 11-30-2008, 10:47 PM
  4. Engine mount idea
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-04-2008, 09:56 AM
