Thread: List of Torque specs
Results 1 to 20 of 22
  1. #1 List of Torque specs
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Chats
    I haven't seen one of these yet around here. I was thinking someone could get a list of torque specs for fastners on our cars. I am about to go through the top end of my regal and replace all the gaskets but I can't seem to remember the torque specs. I hope this was the right section for this.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  2. #2 Re: List of Torque specs
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Chats
    Fastener Tightening Specifications
    Application
    Metric
    English
    Accelerator Control Cable Bracket Bolt
    16 N-m
    12 lb ft
    Air Injection Check Valve Pipe to Exhaust Manifold
    10 N-m
    89 lb in
    Air Injection Check Valve to Bracket Bolt
    25 N-m
    18 lb ft
    Balance Shaft Driven Gear Bolt
    22 + 70° N-m
    16 + 70° lb ft
    Balance Shaft Retainer Bolt
    30 N-m
    22 lb ft
    Camshaft Position Sensor Bolt
    10 N-m
    89 lb in
    Camshaft Sprocket Bolt
    100 + 90° N-m
    70 + 90° lb ft
    Camshaft Thrust Plate Bolt
    15 N-m
    11 lb ft
    Canister Purge Solenoid Valve Bracket Bolt
    50 N-m
    37 lb ft
    Canister Purge Vacuum Switch Bolt
    50 N-m
    37 lb ft
    Connecting Rod Cap Bolt
    27 + 50° N-m
    20 + 50° lb ft
    Crankshaft Balancer Bolt
    150 + 76° N-m
    111 + 76° lb ft
    Crankshaft Main Bearing Cap Bolt
    40 + 110° N-m
    30 + 110° lb ft
    Crankshaft Main Bearing Cap Bolt (Side)
    15 + 45° N-m
    11 + 45° lb ft
    Crankshaft Position Sensor Stud
    30 N-m
    22 lb ft
    Crankshaft Rear Oil Seal Housing Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Cylinder Head Bolt
    50 + 120° N-m
    37 + 120° lb ft
    Drive Belt Tensioner Bracket Bolt/Nut
    50 N-m
    37 lb ft
    Drive Belt Tensioner Bracket Stud
    6 N-m
    53 lb in
    EGR Valve Adapter Bolt/Stud
    50 N-m
    37 lb ft
    EGR Valve Inlet Pipe Bolt
    29 N-m
    21 lb ft
    EGR Valve Nut
    30 N-m
    22 lb ft
    EGR Valve Outlet Pipe Bolt/Nut
    29 N-m
    21 lb ft
    Engine Block Coolant Drain Plug
    30 N-m
    22 lb ft
    Engine Block Oil Gallery Plug
    30 N-m
    22 lb ft
    Engine Coolant Temp Sensor
    23 N-m
    16 lb ft
    Engine Flywheel Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Engine Front Cover Bolt Stud
    20 + 40° N-m
    15 + 40° lb ft
    Engine Lift Bracket Bolt/Nut./Stud
    30 N-m
    22 lb ft
    Engine Mount Nut Lower
    78 N-m
    58 lb ft
    Engine Mount Nut Upper
    78 N-m
    58 lb ft
    Engine Oil Pressure Indicator Switch
    16 N-m
    12 lb ft
    Engine Wiring Harness Heat Shield Nut/Bolt
    10 N-m
    89 lb in
    Exhaust Crossover Heat Shield Nut
    20 N-m
    15 lb ft
    Exhaust Crossover Pipe Bolt/Stud
    18 N-m
    13 lb ft
    Exhaust Manifold Bolt/Nut
    30 N-m
    22 lb ft
    Exhaust Manifold Stud (Inner)
    30 N-m
    22 lb ft
    Exhaust Manifold Stud (Outer)
    10 N-m
    89 lb in
    Fuel Injector Rail Nut
    10 N-m
    89 lb in
    Fuel Injector Rail Stud
    25 N-m
    18 lb in
    Fuel Injector Sight Shield Bracket Nut
    30 N-m
    22 lb ft
    Generator Brace Bracket Bolt
    50 N-m
    37 lb ft
    Heated Oxygen Sensor
    42 N-m
    31 lb ft
    ICM Nut
    50 N-m
    37 lb ft
    ICM Stud
    6 N-m
    53 lb in
    ICM Wiring Harness Bolt
    2 N-m
    18 lb in
    Idler Pulley Bolt
    50 N-m
    37 lb ft
    Idler Pulley Bracket Bolt
    30 N-m
    22 lb ft
    Lower Intake Manifold Bolt
    15 N-m
    11 lb ft
    Oil Cooler Adapter Connector
    50 N-m
    37 lb ft
    Oil Filter
    30 N-m
    22 lb ft
    Oil Filter Adapter Bolt
    15 + 50° N-m
    11 + 50° lb ft
    Oil Level Indicator Switch
    20 N-m
    15 lb ft
    Oil Level Indicator Tube Nut
    19 N-m
    14 lb ft
    Oil Pan Bolt
    14 N-m
    125 lb in
    Oil Pan Drain Plug
    30 N-m
    22 lb ft
    Oil Pump Cover Screw
    11 N-m
    98 lb in
    Oil Pump Screen Bolt
    15 N-m
    11 lb ft
    Power Brake Booster Heat Shield Nut
    20 N-m
    15 lb ft
    Spark Plug
    27 N-m
    20 lb ft
    Starter Motor Heat Shield Bolt
    30 N-m
    22 lb ft
    Throttle Body Nut
    10 N-m
    89 lb in
    Throttle Body Support Bolt
    10 N-m
    89 lb in
    Throttle Body Support Stud
    6 N-m
    53 lb in
    Timing Chain Dampener Bolt
    22 N-m
    16 lb ft
    Upper Intake Manifold Bolt/Stud
    10 N-m
    89 lb in
    Vacuum Solenoid Valve bolt (with NC1 California Emissions)
    10 N-m
    89 lb in
    Valve Lifter Guide Retainer Bolt
    30 N-m
    22 lb ft
    Valve Rocker Arm Bolt
    15 + 90° N-m
    11 + 90° lb ft
    Valve Rocker Arm Cover Bolt
    10 N-m
    89 lb in
    Water Outlet Bolt
    27 N-m
    20 lb ft
    Water Pump Bolt
    15 + 80° N-m
    11 + 80° lb ft
    Water Pump Pulley Bolt
    13 N-m
    116 lb in
    Wiring Harness Shield Bolt/Nut
    10 N-m
    89 lb in
  3. Likes ThatOldCarSmell liked this post
  4. #3 Re: List of Torque specs
    New Salem, ND
    Chats
    WOW thank you very much, that was way more than I expected. Now maybe we can get a sticky made with that info in it.
  5. #4 Re: List of Torque specs
    GTX Level Member webracin's Avatar
    Arkansas
    Chats
    Might want to check out the How To Section as well....
    http://www.grandprixforums.net/torqu...ifications.php
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  6. #5 Re: List of Torque specs
    Las Cruces, NM
    Chats
    haha, I didn't even know that was there. I stole it elsewhere. Same place that came from aparently.
  7. #6 Re: List of Torque specs
    Donating Users bgn87's Avatar
    Kinnelon, NJ
    Chats
    Snout bolts 15 lb-ft
    2002 GTP - 13.66 @ 102.77
    Rolling Performance
  8. #7 Re: List of Torque specs
    Nov 2010
    Hannibal, MO
    Chats
    I need the specs for the valve body and pump bolts. Also those for the bolts holding the cover over the drive chains. Can anyone please help?
    Thanks. Dan
  9. #8 Re: List of Torque specs
    Charles City, IA
    Chats
    3061
    SMGPFC Two Nipple General
  10. #9 Re: List of Torque specs
    May 2020
    Minnesota
    Chats
    What year does this apply to
    I need them for a 2005 GTP
    Doing a head gasket
  11. #10 Re: List of Torque specs
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Chats
    1591
    Quote Originally Posted by OakdaleGTP View Post
    Doing a head gasket
    These numbers will work for both Series 2 and 3 engines. The design of the supercharger/upper intake was the only major difference, and bolting everything down will be to the same spec. (source: just like many here, I've ran a 2006 GTP engine 11yrs for my turbo setup and 2006 LaCrosse engine 13yrs for my supercharged setup, both with combinations of Series 2 and 3 parts all over)
  12. #11 Re: List of Torque specs
    May 2020
    Minnesota
    Chats
    Thank you
    Question- the metal plate that is attached to the trans and engine (passenger side)
    I cant seem to figure out how it goes on, can I go with out it
  13. #12 Re: List of Torque specs
    Banned
    May 2008
    Chats
    1591
    It should connect to the differential cover and the block behind the oil pressure sender. I'd put it on there for the support.
  14. #13 Re: List of Torque specs
    Banned
    May 2008
    Chats
    1591
    BillBoost posted images here:
    2000 GTP Differential swap questions
  15. #14 Re: List of Torque specs
    May 2020
    Minnesota
    Chats
    Thanks
    I put it all back together without the support bracket and it feels bumpy, it feels like the motor mount is bad
    For this 2005 do I have to take parts off to fit it back on?
  16. #15 Re: List of Torque specs
    Banned
    May 2008
    Chats
    1591
    You may have to move the PS pump for access, along with the splash guard in the wheel well.
    Also, check all your mounts to make sure they're snug.
  17. #16 Re: List of Torque specs
    May 2020
    Minnesota
    Chats
    Quote Originally Posted by dezldave961 View Post
    Thanks, that is what I was afraid of.
    Can I drive it like this for a few days, I need it for work
  18. #17 Re: List of Torque specs
    Banned
    May 2008
    Chats
    1591
    It's not a big task... Pull wheel, 3-4 plastic retainers for splash guard, 2x13mm bolts thru PS pulley... Install 4x bracket bolts (loose at first to line them up, then snug down).
  19. #18 Re: List of Torque specs
    Banned
    May 2008
    Chats
    1591
  20. #19 Re: List of Torque specs
    Chats
    98246
    And.. on a 2005 you'll have a slightly different looking engine to trans bracket, but it ends up in the same place.
  21. #20 Re: List of Torque specs
    May 2020
    Minnesota
    Chats
    I tried to line it up for like 40 minutes before I put it back together
    With no luck, I will try again this weekend
    But now I have another problem, after driving the car for more than 10 minutes if I come to a stop sign the rpms stay high
    Like the throttle body is sticking, I can hear the car revs high
    What could be causing that
  1. Cam specs?
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2017, 09:18 PM
  2. 3800 Torque Specs [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 08-24-2013, 01:24 AM
  3. Updated 4T65E Info Page! Torque Specs Added
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-16-2012, 12:13 PM
  4. Quick Q: Torque Converter
    By TommyGloves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2008, 07:06 AM
  5. Possibly Add Torque under edit details
    By JashGTP in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 10:22 PM
