Thread: P0171 - System Too Lean (Bank 1)
Results 1 to 18 of 18
  1. #1 P0171 - System Too Lean (Bank 1)
    Nov 2009
    G
    Vggggg
  2. #2 Re: P0171 - System Too Lean (Bank 1)
    Please search on "P0171" and my user name. Tons of good info already written up. It's early and I'm lazy.
  3. #3 Re: P0171 - System Too Lean (Bank 1)
    MO
    http://www.grandprixforums.net/vaccum_leaks.php
    direct link, make it easy on ya
    <brandonl2000> LMAO D!!
  4. #4 Re: P0171 - System Too Lean (Bank 1)
    Only problem with that write up is it leaves out the EGR tube, battery connections, gaskets, as well as a possibly faulty IAC.
  5. #5 Re: P0171 - System Too Lean (Bank 1)
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Yup, was getting this code a few weeks back so I popped the hood and low and behold 2 vaccum leaks. Both were my fault haha. One was because I didn't cap off the line after removing the L67's MAP sensor and replacing it in the front of the motor using the L36 sensor. Other was the line by the battery leading to the tree on top of the blower. Fixed both and voila, no codes haha
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  6. #6 Re: P0171 - System Too Lean (Bank 1)
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    If it's not a vacuum leak, have you checked the MAF sensor? I put one of those K&N oiled filters in my stock GT and it must have been over oiled from the factory because it dirtied up the MAF sensor and gave me a P0171 code. Cleaned the sensor with throttle body cleaner and I have had no problems for over 4 months now.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  7. #7 Re: P0171 - System Too Lean (Bank 1)
    Illinois
    Has anyone experienced any vacuum leaks near the throttle body. On my 02 GT is looks like there is a vacuum hose connected to the throttle body that then splits off into two hoses, one going to a tiny black canister and another going to another device. It looks like it is starting to crack and I am throwing this code but not experiencing any idle problems. It has been suggested that the fuel filter might need replacing. Any thoughts?
  8. #8 Re: P0171 - System Too Lean (Bank 1)
    Fix the known vacuum leaks first. Always fix known issues before you try to diagnose anything else in the system.
    Fuel filter is possible, but it's not typically the issue.
  9. #9 Re: P0171 - System Too Lean (Bank 1)
    michigan
    Has anyone experienced the car literally lunging forward when letting off the throttle? It feels like I am slowing the car down by compression, like when you are downshifting. I to have the P0171 fuel system too lean on bank 1. Should I also be checking for the vacuum leaks, or is this a bigger fish to fry. I have 141,000 miles on this baby and the mileage has dropped from a steady 24.5mpg to 20.7.
  10. #10 Re: P0171 - System Too Lean (Bank 1)
  11. #11 Re: P0171 - System Too Lean (Bank 1)
    Start with what you know is happening and then fix what's left after you get the obvious issues.
  12. #12 Re: P0171 - System Too Lean (Bank 1)
    Mar 2012
    United States
    I also have a P0171 Code and I checked and changed almost all the vaccume lines. I want to know id the Evap Canister can also cause this problem or no. my Car is a 98 GT 3800.
  13. #13 Re: P0171 - System Too Lean (Bank 1)
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by ferret81 View Post
    Change the egr tube that goes to the lim. It will have a crack in it .Carb cleaner will not catch it and it is not visible without unhooking.
    1997 Red GTP 182000 miles stock
  14. #14 Re: P0171 - System Too Lean (Bank 1)
    May 2008
    Winnipeg, MB
    now I got this code, only after new pcm
    2007 Pontiac Grand Prix
  15. #15 Re: P0171 - System Too Lean (Bank 1)
    Apr 2009
    Fort Worth TX
    So you put an overkill PCM in the car? Why, because of the rockers? Have you tried putting the old PCM back in to see if you still have the code?
  16. #16 Re: P0171 - System Too Lean (Bank 1)
    May 2008
    Winnipeg, MB
    old pcm is in Ontario now
  17. #17 Re: P0171 - System Too Lean (Bank 1)
    May 2008
    Winnipeg, MB
    SES light went out. All I did last night was redo the air intake setup better.
  18. #18 Re: P0171 - System Too Lean (Bank 1)
    Apr 2009
    Fort Worth TX
    Oy YOY.
  1. How to Trace Vaccum leaks for P0171 [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2012, 09:52 PM
  2. code p0171 p0332 wont start now
    By juanathandavid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 05:29 PM
  3. p0420 Catalyst System Efficiency Below Threshold (Bank 1)
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 08-12-2009, 01:05 PM
  4. code P0171 keeps coming back
    By grandprix01 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2009, 01:33 AM
  5. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
