Thread: 1999 grand prix gt window removal??? please help
Results 1 to 9 of 9
  1. #1 1999 grand prix gt window removal??? please help
    Detroit MI
    Chats
    ok does anyone have any idea how to remove a window from the door on a 1999 gpgt. because i have to replace a 2 broken front windows and while i'm at it i'm going to tint them both while there out so it will look perfect. i really need to get the windows out and have no idea how. please help me guys its supposed to rain the day after tomarrow and i dont wanna drive up north with seran wrap windows.
  2. #2 Re: 1999 grand prix gt window removal??? please help
    Wausau, WI
    Chats
    I am not positive, but I think that you will have to take off the inner door trim and remove it from the track and it should turn and come out of the top where it usually resides when it is rolled up.
  3. #3 Re: 1999 grand prix gt window removal??? please help
    Guam
    Chats
    If they are broken, what is there to remove besides the glass with a vacuum?
    If the regulator is not working, take the door panel off by removing the 2 plastic caps covering the 2 screws under the door pull handle, and remove the screws. Remove the window/lock switch and disconnect, pry up on the rear end I believe. Pull off the door panel from its fasteners, disconnect the small speaker from its connector if you have the BOSE sound, you cannot pry its cover off, it will break. Remove the panel from around the door open lever. The panel fasteners are not the greatest and you may break a few doing this too.
    Pull back the clear plastic vapor barrior and then you will have access to all the regulator botls and window.
    I am not sure though on what you are exactly doing, replacing the windows, regulator, or motors?
  4. #4 Re: 1999 grand prix gt window removal??? please help
    Detroit MI
    Chats
    ok i'm going to attempt it after school. is it difficult?
  5. #5 Re: 1999 grand prix gt window removal??? please help
    Guam
    Chats
    Stand by, lemme check something here. Gimme a few minutes...
  6. #6 Re: 1999 grand prix gt window removal??? please help
    Guam
    Chats
    OK, private message me your email and I will email you the GM service manual instructions in PDFs on how to remove everything.
  7. #7 Re: 1999 grand prix gt window removal??? please help
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    Chats
    its not hard at all i just did it like 2 weeks ago
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  8. #8 Re: 1999 grand prix gt window removal??? please help
    Guam
    Chats
    I am leaving work at 4:30 today and then going out of town. So if I do not hear from you before then, you are on your own...
  9. #9 Re: 1999 grand prix gt window removal??? please help
    Guam
    Chats
    Still need your email if you want these PDFs.
  1. 1999 Grand Prix no go
    By Kreitoc in forum General Tech Discussion
    Last Post: 09-27-2009, 03:37 PM
  2. 1999 Grand Prix sometimes won't start
    By sabram in forum Canada
    Last Post: 09-13-2009, 07:31 PM
  3. 1999 Grand Prix GTP rear passenger window & locking problems
    By RYANPOWERSMAIL in forum General Tech Discussion
    Last Post: 05-24-2009, 03:51 AM
