Thread: 2004 3.8 #1 cylinder misfire
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: 2004 3.8 #1 cylinder misfire
    Mar 2020
    MN
    Chats
    As she was telling me about it, I told her the exact same thing that she should have asked to see the defective parts. I figured the gasket might be reusable and yes, even at $400 it is now running good and they are just happy to get the daughters car back to work, I just cant imagine a cylinder having 150psi in a cylinder with a broken valve spring.
    I just thought I would share the results with you guys who have given me suggestions.
  2. Likes Scottydoggs liked this post
  3. #22 Re: 2004 3.8 #1 cylinder misfire
    Chats
    98246
    These are interference engines. If a valve hangs open enough, it'll hit. It sure sounds odd what they said. While you can bolt a valve cover back down without changing the gasket, you can also cause a leak. These gaskets are well known to flatten with years and if this does cause a leak, replace the valve cover grommets at the same time. They apply the pressure from the sleeved bolts in order to seal the gasket.
  4. #23 Re: 2004 3.8 #1 cylinder misfire
    Mar 2020
    MN
    Chats
    Tes, it is running fine now, and they were satisfied with the $400 price. I told her if it ever happens again to request the old parts. Ive been teaching HS automechanics for 38 yrs and I am baffled how a broken valve spring can still make 150 psi but.....
    Thank you for all your help guys. I appreciate it.
  1. GTP cylinder 4 misfire
    By darin4fun in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2015, 09:02 PM
  2. Cylinder #5 misfire
    By SDGTP99 in forum 5.3L V8 (LS4)
    Last Post: 01-23-2013, 09:43 PM
  3. Cylinder Misfire!
    By AFBCamaro in forum Introductions/Noob Questions
    Last Post: 05-01-2010, 09:52 PM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
