Thread: Creaking steering issue
Results 1 to 3 of 3
  1. #1 Creaking steering issue
    Nov 2019
    WI
    Anyone else had their rack and pinion mounting bolts come loose? I am suspecting that issue becauuse mine clunks after a new iss install. It will clunk on smooth ground with no potholes and even without turning the wheel. Thanks guys.
  2. #2 Re: Creaking steering issue
    St. Louis
    It's possible. Climb under it and check it out. Get the front end in the air and turn it lock to lock to isolate the noise. Could be a strut mount, ball joint, tie-rod end, control arm bushings. Just give everything in the front end a good look.
  3. #3 Re: Creaking steering issue
    Nov 2019
    WI
    Thx for the reply. I found another thread on here with a tsb that stated that the holes in the bushings for the rack and pinion where made too large for the bolt diameter and they were working on a fix. They also said that re torquing the bolts would quite the clunk but that it would return. I re torqued the bolts and it's quiet for now.
  1. Steering issue?
    By nickgpgt in forum General Tech Discussion
    Last Post: 04-15-2013, 11:33 PM
  2. creaking in steering wheel when turning left
    By jbyrne in forum General Grand Prix Discussion
    Last Post: 02-16-2013, 11:00 PM
  3. Steering Creaking at Low Speeds
    By Bedwards in forum General Tech Discussion
    Last Post: 06-03-2012, 05:18 PM
  4. No more clunking, creaking or rattle in the steering colum
    By mbeeman350 in forum General Tech Discussion
    Last Post: 12-17-2011, 08:26 PM
  5. steering issue
    By macjns25 in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2011, 01:17 PM
