Thread: Gauge issue
Results 1 to 8 of 8
  1. #1 Gauge issue
    Oct 2019
    spring, tx
    Chats
    Ok so I have a issue. My girl gauge sometimes reads 1/4 than will shoot up to full than drop to empty than show accurate I think than cycle repeats. I have a new fuel pump assembly. Could this be a issue with the cluster?
  2. #2 Re: Gauge issue
    Oct 2019
    spring, tx
    Chats
    Ment fuel gauge not girl gauge my galaxy s6 apparently knows nothing bout car stuff
  3. Likes tomsteve liked this post
  4. #3 Re: Gauge issue
    Chats
    243824
    for real i thought you said you were a mechanic........
    level sensor on the pump canister. you can buy just the level sender and replace it. or the whole canister. <<costs way more. just the sender is like 20 bucks on line.
  5. #4 Re: Gauge issue
    Oct 2019
    Ridgecrest ca
    Chats
    Quote Originally Posted by 01pontgp View Post
    Just to be clear, by assembly you mean you installed the whole shebang, pump, sending unit and strainer?
    If so, there’s the possibility that the connection is bad, the arm could have been bent when inserting in to the tank, causing a loss of connection.
    Harness/plug could be corroded or damaged.
    Look at the gauge as a last item. Unless, there is a salvage yard close to you, grab a new (used) cluster and swap it in. But, to just diagnose an issue that could end up rather expensive.
    There is always the possibility that there is a bad solder joint, or wire in the cluster.
    My point is, it could be any number of things, just offering you some ideas and starting points.
  6. #5 Re: Gauge issue
    Apr 2015
    Columbus, OH
    Chats
    246
    . My girl gauge sometimes reads 1/4 than will shoot up to full than drop to empty than show accurate I think than cycle repeats. ?
    Lol the unintentional humor here cracks me up . I have the same issue but the older I get, the less the cycle repeats.
    Top Swapped 01 Imp
  7. #6 Re: Gauge issue
    Oct 2019
    spring, tx
    Chats
    I replaced the fump/sender assembly cause it's what made most sense. But didn't fix it so I wanted to ask about the gauges before I replaced the cluster cause of my odometer
  8. #7 Re: Gauge issue
    Chats
    243824
    could be a bad stepper motor in the cluster. those are changeable.
  9. #8 Re: Gauge issue
    Oct 2019
    Ridgecrest ca
    Chats
    Just curious if you figured it out? I don’t have this issue, but it’d be cool for the solution to be posted as our cars are getting up there in age and never know if it might become a larger scale issue. Hope you got her fixed!
  1. Aeroforce gauge issue
    By xcwilli11 in forum General Grand Prix Discussion
    Last Post: 06-11-2016, 06:45 AM
  2. Gas gauge issue?
    By LS1GTP in forum Introductions/Noob Questions
    Last Post: 11-04-2012, 10:33 PM
  3. Fuel Gauge Issue
    By Lawenforcer in forum General Tech Discussion
    Last Post: 02-25-2012, 01:47 PM
  4. Rpm Gauge issue
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-27-2011, 10:20 AM
  5. boost gauge issue vid
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2009, 09:44 PM
