Thread: 12V electric power failure
Results 1 to 12 of 12
  1. #1 12V electric power failure
    Nov 2016
    N. California
    Chats
    The 2001 GTP wouldn't start. The electrical system appears to be completely dead, but the battery is at 12.6V. When I probed the large positive wire on top of the fuse box behind the battery it reads 5V, but the reading is unstable. I haven't been able to find the schematic in the manual yet, but I'm guessing something between the battery cable and the fuse box has failed.
    Lifespeed
    2001 GTP
  2. #2 Re: 12V electric power failure
    Oct 2014
    portland oregon
    Chats
    507
    Check your grounds while your at it.. easy one under the battery.
    Sent from my SM-N920V using Tapatalk
  3. #3 Re: 12V electric power failure
    Nov 2016
    N. California
    Chats
    update: looks like the smaller black cable from the battery to the underhood fuse box is rotted and intermittent. Can I buy a new cable assembly anywhere?
    Lifespeed
    2001 GTP
  4. #4 Re: 12V electric power failure
    Oct 2014
    portland oregon
    Chats
    507
    Nailed it lol.. I get that stuff from the junk yard lol..
  5. #5 Re: 12V electric power failure
    Nov 2016
    N. California
    Chats
    Update again (you can't edit posts?): $83 from GMPartsDirect 12157012 Positive Cable
    Lifespeed
    2001 GTP
  6. #6 Re: 12V electric power failure
    Oct 2014
    portland oregon
    Chats
    507
    Sounds steep to me. 5 bucks at the u pull it yard
  7. Likes bandook liked this post
  8. #7 Re: 12V electric power failure
    Apr 2015
    Columbus, OH
    Chats
    246
    I thought you said black cable? That's a positive harness you linked.
    Top Swapped 01 Imp
  9. #8 Re: 12V electric power failure
    Nov 2016
    N. California
    Chats
    Quote Originally Posted by wowitsfast View Post
    LOL, buying another rotted cable and spending an hour or two to install isn't the way I do car repairs. Even an old GTP.
  10. #9 Re: 12V electric power failure
    Nov 2016
    N. California
    Chats
    Quote Originally Posted by bandook View Post
    Yes and yes.
  11. #10 Re: 12V electric power failure
    Chats
    83662
    Napa used to sell battery cables that are pre made in various length for both positive and negative, perhaps they still do.
    I'd check there or at another parts store before buying a new cable from GM, if that is still an option. Even it I couldn't do that I would just make my own cable for like $20. Bulk wire from napa and new cable terminal ends are cheap.
  12. #11 Re: 12V electric power failure
    Oct 2014
    portland oregon
    Chats
    507
    Quote Originally Posted by Lifespeed View Post
    Your in California I'm in Oregon cars here arnt all rotted out.. beat to crap yes but not rotted. Same where you live wires are typically in good condition since W-body's fill the yard.
    No figuring required just go find a good one and take it home.
    Or order it online wait for it to come. Or go by the parts and remake them to length.
  13. #12 Re: 12V electric power failure
    Nov 2016
    N. California
    Chats
    Thanks guys, I appreciate the money saving tips and I know these cars aren't worth a lot anymore. My son has been driving the car for a year, it will be 5 more years before he finishes college and can buy himself a better car. This GTP needs to last a while longer.
    It doesn't burn oil, runs strong and has had regular transmission fluid changes it's whole life. We already rebuilt and FE5'd the suspension, fixed the supercharger drive, belts, water pump, radiator, MAF, brakes and a few other things. I'm OK with paying more for an OEM cable if it fits correctly and stays reliable while he's on his own focusing on school.
  1. Electric power steering retrofit? ('01 GTP)
    By wmorrison65 in forum General Tech Discussion
    Last Post: 10-06-2015, 01:24 PM
  2. Replies: 7
    Last Post: 08-27-2013, 08:57 AM
  3. power steering pump failure
    By GXPrunner06 in forum 5.3L V8 (LS4)
    Last Post: 05-20-2013, 05:46 PM
  4. Failure
    By mechguy in forum Off Topic Discussion
    Last Post: 03-25-2011, 01:39 AM
  5. possible failure yet again??
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-24-2008, 08:40 PM
