Thread: A/c blowing cold on one side only.
Results 1 to 10 of 10
  1. #1 A/c blowing cold on one side only.
    May 2019
    Mobile al
    Hi everyone back again. I got my a/c working but its only blowing cold on one side. Does my grand prix have one or two blend doors?
  2. #2 Re: A/c blowing cold on one side only.
    you have 2. pass side is easy, driver side sucks. Blend Door Actuator Replacement
  3. #3 Re: A/c blowing cold on one side only.
    Apr 2015
    Columbus, OH
    Is it cold on the pass side? Does driver side eventually get cooler?
    Top Swapped 01 Imp
  4. #4 Re: A/c blowing cold on one side only.
    May 2019
    Mobile al
    Thanks Scottydoggs. That's what I thought. I have a 2002 park avenue and it has two.
  5. #5 Re: A/c blowing cold on one side only.
    May 2019
    Mobile al
    I drove it around the block and it stayed the same. It dont blow like the heater is on, its more like luke warm. Also the compressor does not cycle on and off and the a/c will not turn off at the button. Any ideas?
  6. #6 Re: A/c blowing cold on one side only.
    Apr 2015
    Columbus, OH
    Low on freon? If it's low it can also only blow cold on one side, typically the passenger.
    Top Swapped 01 Imp
  7. #7 Re: A/c blowing cold on one side only.
    May 2019
    Mobile al
    I just charged it last week, but I will check it again to make sure it's still full. Thanks for the info. I may need some more help as I'm not an a/c expert. I have worked on cars for 40 years. Most of the cars I have owned have been antique hot rods with out a/c. Once again thanks for the help.
  8. #8 Re: A/c blowing cold on one side only.
    Apr 2015
    Columbus, OH
    I'm no a/c expert either. But I've had 2 vehicles that had the same issue when low on freon. My Impala needs topped off probably every other summer. Pretty sure it's leaking at the low pressure valve because it gives off a hiss when I take the cap off. It will only blow cold on the passenger side until I top it off. But the driver side does eventually get colder when I drive for maybe 10-15 minutes.
    Top Swapped 01 Imp
  9. #9 Re: A/c blowing cold on one side only.
    May 2019
    Mobile al
    I going to check it today. I will let you know what happens.
  10. #10 Re: A/c blowing cold on one side only.
    May 2019
    Mobile al
    I added some more freon and that worked. Thanks for the advice.
  11. Likes bandook liked this post
  1. 05 GXP blowing heat blowing Cold Air! HELP!
    By Timmaayy2121 in forum General Tech Discussion
    Last Post: 01-05-2016, 12:39 AM
  2. Air Conditioner not blowing cold air through passenger side?
    By Pokealong1227 in forum General Tech Discussion
    Last Post: 04-14-2014, 07:16 PM
  3. A/C Not blowing cold
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 08-09-2013, 08:44 PM
  4. A/C not blowing cold
    By draines in forum General Tech Discussion
    Last Post: 06-21-2012, 10:03 AM
  5. Heater blowing cold on drivers side
    By sophie in forum Introductions/Noob Questions
    Last Post: 11-03-2010, 08:00 PM
