Thread: Keeping the fuel pump "sock" on
Results 1 to 3 of 3
  1. #1 Keeping the fuel pump "sock" on
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Hi All,
    My fuel pump siezed and I sent it to AEM for warranty. When i removed it form the car, the sock fell off. I dont know if it fell off while removing it or before. I want to make sure it CANT fall off. Right now im thinking of using some zip ties around the canister to hold it on. the car is running full e85. Any advice?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Keeping the fuel pump "sock" on
    Jul 2017
    macomb mi
    Chats
    62
    I used a small zip tie to hold it to mine made sure it was tight with some pliers and its the longest lasting pump ive had on e85 so far
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  3. #3 Re: Keeping the fuel pump "sock" on
    Kemmerer, Wyoming
    Chats
    60223
    I went with the walbro 255 and had to cut a hole in the bottom of the canister to be able to secure the sock onto the pump. so far no problems.
  1. Still getting "Check Security System" and got "Battery Saver Mode"
    By J57ltr in forum General Tech Discussion
    Last Post: 08-08-2015, 01:36 AM
  2. How to properly reset "shift learn" or "adapt" in 4t65e-HD
    By AndrewGXP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2015, 09:30 PM
  3. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  4. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
