Thread: should i run E85?
Results 1 to 10 of 10
  1. #1 should i run E85?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Chats
    3883
    im coming to terms that im going to need another built trans......so i might as well make as much power as i can. so should i run E85 though? i know i need 80# injectors a pump rewire and a tune...all doable and i need a station near me, theres one a few miles away from my house so check that off i guess my concerns are will this gum up my fuel line and rail? is it worth the power gains? my biggest fear is running out of fuel and not having a E85 station around me. i never have more then half a tank of fuel at a time for weight reduction so should i carry a reserve tank or something? that would definitely be a day ruin er if i ran out of gas lol
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: should i run E85?
    Out West
    Chats
    58707
    du eet
    Whine with your Cheese?
  3. #3 Re: should i run E85?
    Chats
    83662
    You can run 65's with e85.
    You'll need to have it custom tuned to change everything with running e85.
  4. #4 Re: should i run E85?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Chats
    6742
    Run E85.
    Just keep a spare tank like you said if your always low on fuel, or if your going to travel long distance, fill up before hand.
  5. #5 Re: should i run E85?
    Oct 2011
    Michigan
    Chats
    3883
    yeah but with a cam and ported blower im gonna need 80#ers lol and idk man its just a constant fear, i could probably get what 35-50 more BHP right?
  6. #6 Re: should i run E85?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Chats
    7
    Go for it. I also want to run e85 on mine eventually too. If you do go e85 make sure you start a thread about it. It's not done a whole lot and others who are thinking of doing it could defiantly learn from it. I'd go with 80# injectors if you haven't bought anything else already. I wouldn't worry too much about the fuel rail being gummed up. I would worry about the lines being eatten away at tho had a buddy run it on his 350z that had problems. I'd go with staineless steel and teflon coated for anything that has to be rubber.
    I went NA when a whore left -$300 in my bank account.
  7. #7 Re: should i run E85?
    Oct 2011
    Michigan
    Chats
    3883
    well idk id think my GTP is made better then that 350z i could just run it on pump gas
  8. #8 Re: should i run E85?
    Chats
    64942
    Like everything else: If you have to ask
  9. #9 Re: should i run E85?
    Minnesota
    Chats
    5198
    Quote Originally Posted by asite57 View Post
    What cam? I doubt you will need 80s. I have them right now and they are kinda of a pain. But yes you should do E85.
    I hope you are not serious about the weight reduction. Unless you are at the track it is really not going to matter.
    Most people will keep a spare PCM in the car that is setup for regular gas. That way if you get in a spot and you are super low you can swap it out and drive on regular gas taking it easy.
  10. #10 Re: should i run E85?
    Oct 2011
    Michigan
    Chats
    3883
    i plan on doing XP cam with 105# springs on stock heads, yes im serious about the weight thing the difference between a full tank and a 1/4 tank is 100 pounds of weight, on the street you never know when your gonna need to race you should always be ready
    matt i might be agreeing with you...
e85, run
