Thread: metal in oil pan
Results 1 to 9 of 9
  1. #1 metal in oil pan
    Apr 2020
    edmonton alberta
    so pulled the motor on 98 regal gs new timing chain rear seal pan gasket lots of fun but when i cleaned the oil pan i found what apears to be a needle bearing its small half a inch or so long small diameter any ideas?? i would like to know where this came from
  2. #2 Re: metal in oil pan
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Pics or it didn't happen?
  3. #3 Re: metal in oil pan
    Apr 2020
    edmonton alberta
    did not take a picture its in the jug of old oil
  4. #4 Re: metal in oil pan
    Banned
    May 2008
    Possibilities are lifter roller or rocker trunion, off the top of my head. You can start by checking under the valve covers (rockers), and then under the lower intake manifold (lifters). This will let you replace those more common leaking gaskets while you're in there, anyway, along with any upgrading you want to do. You can hit you local Ace/Lowe's/Home Depot to get a set of re-useable rocker bolts (match length of OEM 5/16-18 single-use ones with quality, non-stainless Allen head cap screws like vendors sell for $20).
  5. #5 Re: metal in oil pan
    Apr 2020
    edmonton alberta
    lower intake gaskets and elbows were done last fall didn't notice anything, dealer did front valve cover gasket on recall drove the car from Maricopa AZ to Edmonton Alberta [1800 miles] never used any oil car runs very good just had oil leaks i had changed the oil pan gasket a few years ago fel-pro said only to use rtv on the four corners not this time better not get any more leaks as its got all new gaskets and seals
  6. #6 Re: metal in oil pan
    Banned
    May 2008
    Welp, you got a metal piece. You can either dig in, pull it out with a magnet and take a picture with a ruler... consider having to crack open your engine to investigate... or just roll on.
  7. #7 Re: metal in oil pan
    Apr 2020
    edmonton alberta
    motor is back in the car going to roll on
  8. #8 Re: metal in oil pan
    Apr 2020
    edmonton alberta
    Found needles bearing when cleaning oil drain pan how do you post pics it’s about 3/8 long
  9. #9 Re: metal in oil pan
    GT Level Member mguzzo's Avatar
    Buffalo NY
    either upload it here or host on a 3rd party site and link it here.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. Metal to metal grinding sound
    By luckyg817 in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2015, 04:48 PM
  2. Metal on metal grinding noise?
    By Pontiac Racer in forum Introductions/Noob Questions
    Last Post: 11-17-2014, 09:37 PM
  3. Metal UIM.
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2014, 12:36 AM
  4. metal on metal sound
    By Toms04compg in forum Brakes/Suspension/Chassis
    Last Post: 03-21-2012, 04:54 PM
  5. LS1/LS2 metal oil cap overlay
    By Preotic in forum Visual/Body Modifications
    Last Post: 03-01-2008, 09:57 AM
