Thread: New hub assembly
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    Well, super. The steel idler pulley for the sc seized, shredded the belt. But, it did enlighten me to another issue. After I smelled it and heard the belt go, the car stopped surging when on the torque converter lockup at 55. Literally zero surge. Interesting.
  2. #22 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    Fml. Tcc code, converter is locked up. Ugh!!!!!! I need to get the filter, fluid and solenoid done ASAP.
  3. #23 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    Here ya go. Ridiculous.
  4. #24 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    Does anyone have the link with instructions for pulling the side cover to access the solenoid?
  5. #25 Re: New hub assembly
    GT Level Member mguzzo's Avatar
    Buffalo NY
    youtube it
    there's an entire teardown video for PCS replacement
    start here YouTube
    there's several parts, part 1 is prep, part 2 is dropping cradle, part 3 is removing side cover
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. Likes Gingershrek liked this post
  7. #26 Re: New hub assembly
    You can do it in the car.
    Jack and support car
    Drain trans and put pan back on
    Pull drivers axle
    support trans from below
    Remove trans mount
    lower that side of subframe
    Undo electrical connector to top of trans
    undo all the bolts around the side cover and wiggle cover to best position for room
    go in and do that solenoid being very careful you don't snap the connector tab.
    Reassemble and make sure that big o-ring on the cover is sitting in place before you put side cover back on.
    It's not so bad. I recently did a shift soleniod in a Malibu. It's a bit tighter in there.
  8. Likes Gingershrek liked this post
  9. #27 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    It honestly doesn’t look that bad. Mostly it’s small time consuming stuff.
    On another note, she drove home again, not a peep or hesitation and the ses light never came back on. What the actual f$&k. Just weird. Vehicles I’ve had in the past have been manual or a 700r4. Manual I’ve never had to rebuild, the latter was so cheap it was throw it away and grab another out of the junk yard.
  10. #28 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    Alright, other rear hub, solenoid, pan gasket, idler pulley and new belt are on the way. Should be in tomorrow.
  11. #29 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    Quick question, are the trans pan bolts blind? Do they need rtv?
  12. #30 Re: New hub assembly
    use the thick factory gasket, aka re use the old one. clean it the pan and tranny mating surface well. then just bolt the pan back on. use no rtv or anything else, dry bolts and gaskets.
  13. #31 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    I put a tiny bit of rtv around the base of the head. That sounds bad. Haha. I used a new OEM gasket, I figured the one on it was going to be trash as the bolts were tight, but it was leaking all over. It’s all done. New solenoid is in, filter in, hub changed, new idler pulleys installed, new tensioner installed, gates belt, she runs pretty good. I am thinking the trans is getting tired though. It shift a little smoother now, converter lock up is positive and solid. Fourth feels good, no slipping, but it just feels lacking. Maybe it’s me.
  14. Likes Scottydoggs liked this post
  15. #32 Re: New hub assembly
    well done
  16. #33 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    Also, I will add this, this diagram is incorrect. The 419-610 is a 2.997” pulley, NOT a 3.5. I ordered the 419-610 from amazon in dorman flavor, but since the shipment was going to be late, I went to oreilly and bought their brand that their computer suggested, which was a 3.5” pulley.
  17. #34 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    And the 419-602 is in fact 3.5”. This has them reversed.
  18. #35 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    One more question, I’ve been using the aircraft paint stripper aerosol to remove the previous owners black spray paint from the wheels. It has worked great up to the point I’m at. The wheels are shiny aluminum mostly all over now, but, there is still black paint here and there. It’s not removing it anymore. Any suggestions? We do have a very high presser setup at work, I plan on using it to see if it helps, but short of that, I’m out of options.
  19. #36 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    Second rear hub on the way. Started hearing a little noise from the left rear now. Get it before it’s catastrophic. I have a list of about $575 in parts needed and another 400 in parts wanted. Haha.
  20. #37 Re: New hub assembly
    St. Louis
    Yep. Quit wasting time on them and find a j-yard or craigslist seller that has a full set of the wheels you want and swap em out.
    Barring that I'd try the pressure washer route first. Then paint thinner. You have to be careful to not let it sit too long otherwise it can damage the factory clearcoat underneath and then you're right back at square one with having to re-coat them. If you scrub on them I'd use a brush or something light to avoid scratching the finish.
  21. #38 Re: New hub assembly
    Oct 2019
    Ridgecrest ca
    I’ll post up a pic after work. I got 99% of it off. They’re looking pretty good now. Just little bits here and there left in the spokes.
  22. #39 Re: New hub assembly
    FWIW, if you aren't looking to have them be chrome, I used this on a car that had horrible clear coat peel and the wheels looked spectacular. Not sure about longevity as the car was flipped. Robot Check
    Sanded the clearcoat so they were smooth and painted them up. You would have thought they were factory wheels in great shape.
  1. gt shifter assembly in a gtp
    By War97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-24-2014, 10:31 PM
  2. Are these symptoms of a bad hub assembly?
    By nawarkk in forum General Tech Discussion
    Last Post: 02-18-2010, 09:28 PM
  3. How to install a Hub Assembly
    By packerfanjc in forum Tires & Wheels
    Last Post: 08-25-2009, 06:31 PM
