Thread: Strange Engine Problem
Results 1 to 6 of 6
  1. #1 Strange Engine Problem
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Chats
    I've never had something like this happen before. Occasionally the stereo will get very loud for a second, the speedometer will fluctuate. and then the engine will shut off. Sometimes the first two things will happen and the engine keeps running, but is sluggish for a few seconds.
    Any ideas?
  2. #2 Re: Strange Engine Problem
    St. Louis
    Chats
    On what year car? If a later one maybe the BCM or ignition switch?
  3. #3 Re: Strange Engine Problem
    Jul 2016
    Brevard County, FL
    Chats
    Quote Originally Posted by fordman77 View Post
    on what year car? If a later one maybe the bcm or ignition switch?
    2007 gxp.
  4. #4 Re: Strange Engine Problem
    St. Louis
    Chats
    Might sound dumb, but check to be sure both battery cables are clean and tight. I've had some strange issues in the past when one is even slightly loose.
  5. Likes tomsteve liked this post
  6. #5 Re: Strange Engine Problem
    Apr 2014
    commerce twp,mi
    Chats
    Quote Originally Posted by FordMan77 View Post
    different make but i had a 96 taurus that started getting a crapton of strange elec issues. turned out to be the positive cables themselves. they were corroded inside the insulation from one end to the other.
    08 grand prix NA3800
  7. #6 Re: Strange Engine Problem
    Jul 2016
    Brevard County, FL
    Chats
    Turns out, it was the engine harness making the speed sensor misbehave. The clip that was supposed to hold it to the block was plastic, in one of these cars, so it disintegrated and the CV axle did the rest.
  1. Guess who has another strange problem!
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2014, 08:03 PM
  2. Strange problem......
    By Spike89 in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2012, 12:22 AM
  3. STrange car problem. Need help quick
    By Logan541 in forum General W body
    Last Post: 10-17-2011, 05:46 PM
  4. strange problem
    By LSXHP in forum General Tech Discussion
    Last Post: 01-15-2011, 01:35 AM
  5. very strange problem.
    By maniakmyke in forum General Tech Discussion
    Last Post: 03-04-2010, 04:45 AM
