Thread: No Cruise or Tapshift
Results 1 to 8 of 8
  1. #1 No Cruise or Tapshift
    Oct 2018
    iowa
    Chats
    My 04 gp gtp comp g recently had the cruise and tap shift stop working. Ive replaced all the cooling in the car so finally thats all good to go. But now the cruise and tap shift stopped working.. Ive checked all the fuses and everthing else related to it that I can think of. Also no codes present. I dont know why it stopped need help. Thanks
  2. #2 Re: No Cruise or Tapshift
    Chats
    83662
    Check all your brake lights just to make sure one bulb is not out. If the 3rd brake light is out, CC can stop working.
    Or the brake light switch on the pedal is sticking/bad.
    I'd look at those two things first.
  3. #3 Re: No Cruise or Tapshift
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Chats
    1417
    I had a bad crank sensor that made the cruise not work.
    Tapsh*t sucks anyways. I almost never use those, so I would've had no idea. Lol
  4. #4 Re: No Cruise or Tapshift
    Oct 2018
    iowa
    Chats
    Quote Originally Posted by SaukRapids View Post
    i never use it just noticed it also stopped working same time.
  5. Likes SaukRapids liked this post
  6. #5 Re: No Cruise or Tapshift
    May 2016
    MN
    Chats
    1417
    Does it disengage cruise while driving? That's what ours starting doing before the balancer took out the cps. Well... so then I had a bad harmonic balancer and the cps was fine, really. Lol
  7. #6 Re: No Cruise or Tapshift
    Oct 2018
    iowa
    Chats
    the cruise never engages when i flip the stock
  8. #7 Re: No Cruise or Tapshift
    May 2016
    MN
    Chats
    1417
    If there's no code, I'd give that balancer an inspection around the rubber edge. It could be deteriorated. I didn't notice the engine shaking any more, but when I put a new balancer on there was a definite difference.
  9. #8 Re: No Cruise or Tapshift
    Oct 2018
    iowa
    Chats
    Still no cruise
  1. where can I buy a tapshift overlay?
    By sho89mtx in forum Wanted To Buy - Parts
    Last Post: 06-22-2016, 07:16 AM
  2. Tuning non-TAPShift PCM to run a TAPShift transmission
    By April Thompson in forum PCM Tuning
    Last Post: 08-13-2015, 08:28 AM
  3. T.T.T Tapshift
    By Speedy1973 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2014, 04:54 PM
  4. tapshift schematics?
    By GeeXPee in forum General Tech Discussion
    Last Post: 06-15-2011, 04:41 PM
  5. how bad is tapshift?
    By BoostedComp in forum 04+ Specifics
    Last Post: 07-15-2009, 10:47 AM
