Thread: Need you help. Car won’t start
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 69
  1. #1 Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    Hey guys. I’m sure most of you have seen my ongoing issues with my 2008 Grand Prix. I’ve just had a rack and pinion job done. Drove fine until Friday I pull into my driveway and I feel it losing power. So I turned it off and now it chugs like it wants to start but won’t. I’ve checked everything I can with my limited tools and knowledge. I even just cleaned the throttle body thinking that would help. My local shop who is willing to look at it has a habit of overcharging but I need my car for work. He said it could be the ignition module. Scotty, if you’re out there, any ideas for a fellow Jerseyite? Any help is desperately needed!!
    John
  2. #2 Re: Need you help. Car won’t start
    Chats
    243824
    if it just lost power id thing fuel pump could have went out. open the black cap on the fuel rail, key to run, push the pin inside in, watch your eyes if you have good fuel pressure it will fly out 2 feet easy.
    if it dribbles out or has a short burst you got no pressure.
  3. #3 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    I’m an idiot. Where is the black cap and where is the fuel rail?
  4. #4 Re: Need you help. Car won’t start
    Chats
    243824
    the metal tubing thats over your blower or intake, rad side of the engine you'l see a black cap, unscrew it, under it is a large tire valve stem looking port. push the pin like you would to let air out of a tire.
  5. #5 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    Checked it and it flew right out. There’s definitely pressure.
  6. #6 Re: Need you help. Car won’t start
    Chats
    243824
    could be the icm. if you take it off auto zone can test them at most locations. id call them first.
  7. #7 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    Called autozone and they seemed to agree it’s the ICM. next question, where is it located? Can’t find a video anywhere
  8. #8 Re: Need you help. Car won’t start
    Chats
    243824
    its under the coil packs. they aint cheap at a parts store. like 100 bucks or more iirc.
    remove the 3 coils, then un bolt the wire harness plug, 6 or 7 mm iirc then un bolt it from the bracket.
    the harness you take off can also fail. check the wires at the plug for any cracks or bare wire showing.
  9. #9 Re: Need you help. Car won’t start
    Chats
    243824
  10. #10 Re: Need you help. Car won’t start
    Oct 2014
    portland oregon
    Chats
    507
    Disconnect negative battery cable before you start horseing around with wires
    Sent from my SM-N920V using Tapatalk
  11. #11 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    I took it off and found her little corrosion. Scraped it off hoping it would start but no dice. If you were me, would you take it to a shop
    To be sure of the problem or would you get the ICM? I don’t have money to waste but it really seems like this is the problem.
  12. #12 Re: Need you help. Car won’t start
    Chats
    243824
    where in north jersey are ya? i got a spare one id give ya. my cars for sale next month i wont be needing it no more.
  13. #13 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    I’m in mount olive.
  14. #14 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    Do you think that’s what I need?
  15. #15 Re: Need you help. Car won’t start
    Chats
    243824
    thats a ride, im in hackensack.... it could be. its hard to tell not being there.
    you can also take a plug wire off the coil, prop it over the coil and crank it over watching if a blue spark jumps to the wire.
  16. #16 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    No sparks on any coil. I’m actually at the auto store now. If this doesn’t do it then it must be the wiring.
  17. #17 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    If I had more time I’d travel to Hackensack for sure but if this doesn’t work I have to get a rental by Monday. I’ve missed way too many days of work because of this car. But knowing my luck, it’ll be the wiring instead of the ICM. that’s the kind of luck I have with this car
  18. #18 Re: Need you help. Car won’t start
    Chats
    243824
    were they able to test the old one? no sparks at all from any coil would be the icm id think for sure.
  19. #19 Re: Need you help. Car won’t start
    Chats
    98246
    ICM is not all that common overall.
    and for reference the connector is a 7mm, the ICM bolts are 5.5mm
  20. #20 Re: Need you help. Car won’t start
    Mar 2016
    NJ
    Chats
    Well I just wasted $135. Still won’t turn over.
  1. Weak Start Up/Start Up Issues
    By PontiacZack in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2018, 01:51 PM
  2. 06 Base Rough Start with Auto Start
    By jenebo in forum 04+ Specifics
    Last Post: 08-30-2016, 11:24 AM
  3. 2002 GTP Stalled at Cold Start; Now Won't Start at All
    By Nick8478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2015, 04:51 PM
  4. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  5. 1990 3.1 lit hard start/ no start. fuel pressure prob
    By wadd in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2015, 07:22 AM
