Thread: PS pump filter worth it?
Results 1 to 9 of 9
  1. #1 PS pump filter worth it?
    Apr 2014
    commerce twp,mi
    im finally tired of the PS pump on my 08 soudin a bit like a supercharger so time to replace it. first time in 35 years of cars ive had to replace a PS pump and dont think i had ever heard or read of a filter for the PS until now and wondering if a filter would be worth it.
  2. #2 Re: PS pump filter worth it?
    HUDSON
    If I would have known I would have never got rid of my original pump, only it was leaking from the shaft but made no noise at all. The first replacement was noisy all the time cold and hot, took it back to AZ and the gave me another one, this second replacement only starts to wine a little when it starts to get real hot like driving in slow heavy traffic or driving in parking lots. I got tired of removing the pump so I left the second replacement in place, that was a couple years ago, but at least it works, but now a hyd. line on the rack is leaking.
  3. #3 Re: PS pump filter worth it?
    St. Louis
    No need for a filter just put new clean fluid in it and call it a day. Bleed it with the front end up in the air and turn it lock to lock around 15 times to get the air out. Keep topping off the pump during this. Once it stays full and has no bubbles in the fluid take it for a drive. Check the fluid level again once it cools down and top off as necessary.
  4. #4 Re: PS pump filter worth it?
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by FordMan77 View Post
    thatnks, fordman. when turning wheel lock to lock- i spose thats with the car running? and definately gonna have the front end up. makes it a little easier on my old knees
  5. #5 Re: PS pump filter worth it?
    St. Louis
    Yep, car running. It will likely whine for a bit until most of the air is out. I try to turn it as fast as I can just to make it work hard.
  6. #6 Re: PS pump filter worth it?
    Apr 2014
    commerce twp,mi
    cool and thanks. warming up a bit this weekend so ill be pullin it into my shop to get r done. might even remember to snap some pics and start a thread as i couldnt find a how to for the 04-08.
  7. #7 Re: PS pump filter worth it?
    St. Louis
    Good luck. I wish it would warm up here. I don't even want to go out in the garage and work on the 02 Cadillac sitting there. I can't work well in a 25* garage.
  8. #8 Re: PS pump filter worth it?
    Apr 2014
    commerce twp,mi
    i hear ya there. i used to be a carpenter- rough framing. worked all year round in michigan. i used to be able to do work in these low temps. i got knocked onto disability back in 2006 after a stage 3 metastic melanoma diagnosis( i think that had something to do with workin and playin outside for years) and the crap i had to go through the next 2 1/.2 years. one thing was a pretty harsh chemo that now has me a wee bit sensitive to heat and cold. when i used to be able to work in the winter with fingerless gloves, now my fingers freeze pretty easily.
    the arthritis from followng a career my body isnt designed to do doesnt help much either.
  9. #9 Re: PS pump filter worth it?
    Apr 2014
    commerce twp,mi
    welp, got r done today but beings how it is NOT a fun job, i didnt take any pics. pretty simple- take out the old and put in the new.
    and its quiet again! between replacing that and the steering flush i did following this write up
    How to Flush/Change Power Steering Fluid on the 3800/3.8L Engine
    it took about 5 old man hours.
  1. Fuel Pump Hotwire kit worth it?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 05-12-2014, 05:14 PM
  2. Fuel Pump or Filter?
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2010, 04:42 PM
  3. Fuel Pump or Filter?
    Last Post: 01-18-2010, 11:13 AM
  4. Fuel Pump or Filter?
    Last Post: 01-18-2010, 11:12 AM
  5. Going to Burger King was not worth it - Water pump
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2009, 02:02 PM
