Thread: Service Stability Traction
Results 1 to 2 of 2
  1. #1 Service Stability Traction
    Dec 2018
    Iowa
    Hey All,
    Been fixing up a 2004 Grand Prix GTP. and have a few things I'm still working on. I have replaced front and rear brakes and rotors also both from wheel bearings ( one harness ). The wires and connections are all good. Every light is off ( which was all the ABS lights ), except the damn Service Traction Stability light. I've also replaced the front and rear struts, not that it had anything to do with it, just wanted those replaced too...
    Any idea what it still could be? I heard possible Steering/angle Sensor? looks like a pain to replace. Just wondering if there are some other thoughts what it could also be before I blow my wad on that.....and if doesn't work would really pee me off....
    Thanks
  2. #2 Re: Service Stability Traction
    at this point being you put on so many new parts, id find a shop and have them scan it for codes.. you'll have a long list of stored codes, ask them to clear them all, then see what code comes back asap cause it will come right back in most cases. might have to drive 30 feet, but it will trip. then follow what ever that code says.
  1. Service ABS/Stability/Traction/Brake System
    By Perma in forum General Grand Prix Discussion
    Last Post: 06-01-2015, 06:38 PM
  2. Traction Control Off / Stability Control Off / Service ABS System
    By compro in forum Brakes/Suspension/Chassis
    Last Post: 12-21-2012, 09:37 AM
  3. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
  4. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  5. abs/traction/stability service lights
    By jackster1234 in forum General Tech Discussion
    Last Post: 11-09-2010, 01:01 AM
