Thread: Engine swap
Results 1 to 5 of 5
  1. #1 Engine swap
    MINNESOTA
    Chats
    I have a 2005 (Comp G)
    3.8 supercharged
    But my engine is going, it has a knock
    I found a 3.8 supercharged engine, but it's a 2007
    Can I just swap engines without having any issues, or do i have to swap other things from the 2007 to my car
  2. #2 Re: Engine swap
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Chats
    10330
    If the 07 engine is complete, I would say just keep the 05 engine while you're doing the swap, but there wasn't any change in L32s between 04-07 mechanically...
    There might be a few different plugs on sensors, but that's it. Once the new engine is in the car and running fine, you won't need the 05 engine anymore.
    I might be interested in some of the parts off the old engine, if you're willing...
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Engine swap
    MINNESOTA
    Chats
    Quote Originally Posted by WarStryker13 View Post
    Nice, thanks
    Let me see how it goes, I was thinking to maybe rebuild the engine on my 2005 while is out
    Wasn't thinking of junking the engine
    But I will let you know
    Hopefully I can start on it this weekend
  4. #4 Re: Engine swap
    Oct 2014
    Frederick, MD
    Chats
    10330
    You've been on here a while, you should know what happens if you don't have the block machined properly... At least I hope you've seen the term "500 mile rebuild" on here. Repeatedly.
    If you've got a damn good machine shop that knows 3800s, more power to ya, but as you probably already know it's much cheaper and less work to find a junkyard short block, rather than try and have a machine shop line-hone all of the mains and everything else, deck and surface everything, etc...
  5. #5 Re: Engine swap
    Chats
    98246
    All sensors and connectors should be identical. If you use the how to swap an engine in the how to section the only thing that is much different is the diff to engine bracket looks different and it attaches to the oil pan vs engine. Nothing material to talk about though.
  1. Engine swap / Trans swap 2001 gtp v. compatible years
    By Banana Hammock in forum General Grand Prix Discussion
    Last Post: 07-06-2016, 08:27 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
