Thread: Bilstein Coilovers
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 121 to 140 of 145
  1. #121 Re: Bilstein Coilovers
    I live here. DirtDog's Avatar
    Jun 2012
    Bum bum bummmm
  2. #122 Re: Bilstein Coilovers
    Quote Originally Posted by Turbocharged400sbc View Post
    yeah till ya s*** a brick at the cost of the material
    Lmao group buy
    04 Comp G.
  3. #123 Re: Bilstein Coilovers
    Jun 2012
    I'd be in
  4. #124 Re: Bilstein Coilovers
    Arizona
    1/2 inch thick x 8" x12" inch aluminum sheet how much would you charge if I sent it to you yo water jet?
  5. #125 Re: Bilstein Coilovers
    hangover park IL
    Yer anal virginity
    ~James~ Psychotic Gearhead
  6. #126 Re: Bilstein Coilovers
  7. #127 Re: Bilstein Coilovers
    Arizona
    Military already gaped me
  8. #128 Re: Bilstein Coilovers
    Jun 2012
    Well ****. I plan to install my front coil overs and rear suspension stuff this coming weekend
  9. #129 Re: Bilstein Coilovers
    Arizona
    Alignment done car has a noticeable sharper turn in, she needs helper springs and maybe its time for shorter springs . I did get my stb back on and functional.
  10. #130 Re: Bilstein Coilovers
    Never Never Land
    Oh. Sweet. I'm kind of in love.
  11. #131 Re: Bilstein Coilovers
    hangover park IL
    did you by chance get measurements of those openings in that plate?
  12. #132 Re: Bilstein Coilovers
    Arizona
  13. #133 Re: Bilstein Coilovers
    Arizona
    Also as an update had to run back through and re tourqe the bolts now that everything's settled in. Also had to make a ride height adjustment. Somehow the passenger coilover was slightly higher. So now all is done, no I'll issues to report on these and I may have found the camber plates of a more correct size to fit in the factory holes so no drilling of the body should be required of these
    http://m.ebay.com/itm/141173611966?nav=SEARCH
  14. #134 Re: Bilstein Coilovers
    hangover park IL
    need also slot to slot dimensions to be able to confirm your other dimensions please
  15. #135 Re: Bilstein Coilovers
    Arizona
    2.30 inches from slot to slot
  16. #136 Re: Bilstein Coilovers
    hangover park IL
    i meant measure slot to slot iD/OD, not the length of yer pecker....
  17. #137 Re: Bilstein Coilovers
    Arizona
    What other id od? You talking the bearing piece?
  18. #138 Re: Bilstein Coilovers
    Arizona
    Working on another project straight up spherical bearing stock mounts with removable bearings .
  19. #139 Re: Bilstein Coilovers
    hangover park IL
    i was kinda looking at the same thing for the TR but with the spherical moved 1" inboard and laying back the strut/welding on reinforcements
    problkem im having is that the upper mounts curved and alum plate dont like that...the zzp junk is 1/4" steel and heavy as hell...sigh
  20. #140 Re: Bilstein Coilovers
    how much built in camber/caster would you even shoot for?
  1. Given up on coilovers
    By carcrobatics in forum Brakes/Suspension/Chassis
    Last Post: 06-10-2013, 12:33 AM
  2. Bilstein HD?
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2013, 10:07 AM
  3. Bilstein Rear Struts...
    By Alsafi92 in forum Wanted To Trade
    Last Post: 01-29-2013, 04:11 PM
  4. agx vs bilstein
    By 06PONTGP in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2012, 08:59 PM
  5. Bilstein offered for 97-03??
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 10:30 AM
