Thread: Bilstein Coilovers
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 101 to 120 of 145
  1. #101 Re: Bilstein Coilovers
    they go through camber change when the suspension compresses.
    looks like a good start to a nice spherical bearing upper mount. using rubber/poly as your flex joint is always silly.
  2. #102 Re: Bilstein Coilovers
    hangover park IL
    you ge tthe ebay junk yet?
    ~James~ Psychotic Gearhead
  3. #103 Re: Bilstein Coilovers
    Arizona
    Yea sure did the plate is about a half inch in diameter to small to use for our cars so I have to return them and find another solution
  4. #104 Re: Bilstein Coilovers
    hangover park IL
    well ****, just redrill 2 holes and use one oem
  5. #105 Re: Bilstein Coilovers
    Arizona
  6. #106 Re: Bilstein Coilovers
    Arizona
    Could weld tabs but I don't want that kind of worry
  7. #107 Re: Bilstein Coilovers
    Looks like if you can exchange them for a slightly bigger one overall then do some trimming if needed then it could work.
  8. #108 Re: Bilstein Coilovers
    hangover park IL
    cut out the middle of the OEM plates and bolt that to the OEM plate
  9. #109 Re: Bilstein Coilovers
    Arizona
    Nope that's the absolute biggest they have. I asked the rep already.. So freaking close too.
  10. #110 Re: Bilstein Coilovers
    Arizona
    Quote Originally Posted by Turbocharged400sbc View Post
    I've thought about it. But it would probably take away from the either the OEM plate or the camber plates strength.
    Here are more pics for reference
  11. #111 Re: Bilstein Coilovers
    Hmm I'll have to look more at it when I get on the computer.. Maybe just have to go another route and buy a bigger one from another seller then cut and trim if needed..
    04 Comp G.
  12. #112 Re: Bilstein Coilovers
    Yea maybe cut out the middle.. Trim the plate just a tad bit around where the studs would go and then weld the plates together.
    04 Comp G.
  13. #113 Re: Bilstein Coilovers
    hangover park IL
    Quote Originally Posted by 91parkave View Post
    you just drill the oem plate and countersink it a little for some flush head bolts.
    keep in mind the weight is all gravity, and cornering loads are at the end of a long lever (no leverage)
    i just know that the oem strut tower has plenty of meat for you to drill 3 or 4 new holes closer to the strut centerline (within the dia of that plate)
  14. #114 Re: Bilstein Coilovers
    Arizona
    Well as usual your right , on my to return these to the post office and decided to see if the strut tower had the clearnence. A detail that I never thought of for some reason. I can utilize a 4 bolt setup for the plate to body and drill the stb brace but leave it as is. Should be a super strong setup.
    The stack will look like this. I'm pretty excited now
    Now I just need to get my measurements symmetrical and drill.
  15. #115 Re: Bilstein Coilovers
    hangover park IL
    quit bein a pessimistic ***** communist and get it done
  16. #116 Re: Bilstein Coilovers
    Arizona
    Heres the deal on the plates, measuring is key, everything else will be plug in play for asny shock we currently use, the universal camber plate comes with bushings already, all that is required id drilling the threaded one out till there are no threads and the factory nut goes on top.
    The great thing now is that the thrust bearings can go up top on the spring hats, when i find time in the future ill order another set of thrust bearings and put them on bottom as well.
    you then end up like this, I would highly recomend helper springs or going back to 12" springs.
    If i could do it over again i would have made a template, which i still probably do of the factory mount and had that cut out on some aluminum plate and bolted it all together for more contact surface on the strut tower
  17. #117 Re: Bilstein Coilovers
    hangover park IL
    it would be real easy for me to water jet that out of aluminum
  18. #118 Re: Bilstein Coilovers
    I live here. DirtDog's Avatar
    Jun 2012
    O really now??
  19. #119 Re: Bilstein Coilovers
    Arizona
    Let's do it t then
  20. #120 Re: Bilstein Coilovers
    hangover park IL
    yeah till ya s*** a brick at the cost of the material
  1. Given up on coilovers
    By carcrobatics in forum Brakes/Suspension/Chassis
    Last Post: 06-10-2013, 12:33 AM
  2. Bilstein HD?
    By Akuch26 in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2013, 10:07 AM
  3. Bilstein Rear Struts...
    By Alsafi92 in forum Wanted To Trade
    Last Post: 01-29-2013, 04:11 PM
  4. agx vs bilstein
    By 06PONTGP in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2012, 08:59 PM
  5. Bilstein offered for 97-03??
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2010, 10:30 AM
