Thread: Pre- Gen Hub Bearing Questions
Results 1 to 5 of 5
  1. #1 Pre- Gen Hub Bearing Questions
    SE Level Member SpecialEdition01's Avatar
    May 2013
    Detroit
    So my girlfriend has a 1995 GP SE and the pass. hub is bad, had the light scanned by O'Reillys.
    I've never done one on a pre-gen, I've heard there are possibly four bolts holding the bearing from the back?
    and does anyone know what the axle nut size is?
    any other differences I should be aware of?
    and (just out of curiosity) are the back similar to the procedure of the 97-03?
    Thanks in advance.
  2. #2 Re: Pre- Gen Hub Bearing Questions
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Yes there are 4, I think it's a 36 but I kept getting different size nuts with the different bearings I did, worst part about the job was just was just breaking loose the corroded bolts holding it in the first time I did it.
  3. #3 Re: Pre- Gen Hub Bearing Questions
    May 2013
    Detroit
    I did it yesterday, and luckily, all of those corroded bolts you speak of came out in one piece. I ended up having to reuse them and despite the corroded ends, the thread was intact. Th axle nut turn out to be a 35.
    I'd say the hardest part about it was was indeed those 4 bolts holding the hub bearing from the back. Even after breaking them they were stubborn to back out of the hub completely.
    2001 GTP 4dr Special Edition
  4. #4 Re: Pre- Gen Hub Bearing Questions
    Feb 2010
    Cleveland
    If you like those have you tried doing ball-joints on one?
  5. #5 Re: Pre- Gen Hub Bearing Questions
    May 2013
    Detroit
    No.. but I've heard stories.
    And I wouldn't say I like those, but there are worse things to do in life. Like a colonoscopy...lol
  1. Wheel bearing/hub assembly questions
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 05-16-2015, 05:21 PM
  2. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  3. wheel bearing questions
    By Austins01GP in forum General Tech Discussion
    Last Post: 08-13-2012, 04:21 PM
  4. Wheel Hub Bearing questions?
    By dew1520 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2009, 08:42 PM
  5. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
